Question Does Any body knows the difference?
Dear Friends,
I was looking for a throttle Linkage Mounting Plate to install on my 3.6 that came out a 964
Then searching for this part I found two part number ( that for me looks like the same part) with very different price between them
on is 911 110 234 1R and the other one is 911 110 234 00
Thanks for the help
Old 09-04-2017, 09:05 PM
There is a difference in the position of the right side ball connection. Top unit has the ball pointing to the other arm, the bottom unit has it pointing to the outside of the plate. I can see why a different part number, but not a wide price differential
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-04-2017, 09:32 PM
ROW '78 911 Targa
timmy2's Avatar
Easy enough to flip the arm over, take off the nut and change it. If you've changed the bushings before, you know that piece comes off.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-04-2017, 10:18 PM
Flojo's Avatar
yes.
unless the arm of the upper one is a different length (can't tell from picture angle)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-04-2017, 11:13 PM
