specs for 901 gearbox diff set up
I am about to look into a 914-6 with a 901 gearbox making a loud clunk at the differential when moving from a stop or changing gear. What are the specifications for the diff set up and backlash? I assume that adjustment is via shims? Where to get those?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
gearhead
It is scribed directly on the parts.
I bet you find a tooth missing from the pinion.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Ouch !!!
OK, update.
There was no scribe on the part that I can see. Admitted, the diff was inside the case and only the side cover was removed. No teeth are missing and it does seem to me like there is too much backlash. What spec should I shoot for and do the shims get installed on the non-cover side or the cover side of the diff housing. If on the non cover side, then the gear box seems like It has to be totally disassembled before you can get the pinion out and then the diff out.
Under the radar
This is for a 911. The shims go on the diff under the bearings. Beside the ring gear being on the back side, I don't know what else is different on a 914.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 09-11-2017 at 07:14 PM.. |
gearhead
Ah...key technical details are confusing. My first answer was inaccurate because reading in the 911 forum about a 901 gearbox I ignored the 914 piece.
You've got an F ed up deal there. Someone took a 901 gearbox and flipped the ring and pinion to run it mid-engine. No, you won't see the specs without getting it all the way down and then it won't matter. Thats not set up according to any factory spec. Someone did that by feel and they did it wrong. You don't want this job. Its a nightmare. Post pictures so others understand. 944s have the diff locked in like that, but not 911S or 914S. Whole thing is coming apart to do it right.
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
It's on a 914-6 where the 2.0L engine is forward of the gearbox, which is reverse of the 911 where the gear box is in front of the engine. Therefore, to have forward moving rotation, the differential has to be flipped to the other side. You are right, this whole thing needs to be totally torn down to do it right.
gearhead
