-   -   How to remove a 911SC Airbox ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/96829-how-remove-911sc-airbox.html)
domanows 02-03-2003 06:12 PM
Hello, I am new to this forum, and diligently trying to develop some mechanical skills. I am trying to remove the airbox on my 1983 911 SC to install a blowoff valve, get some real-estate to install a new engine compartment pad, and remove my throttle body that is in dire need of repair. I have purchased numerous books including "101 Projects for your Porsche" and been to the Pelican Parts technical site.
I have removed all of the screws on the bottom of the airbox and now confused as to what more I need to remove. It appears that the throttle body must come off with the airbox and furthermore, the fuel distributor (maybe wrong term) also appears to be attached. In the picture on the Pelican technical site, the airbox only seems to be attached to the throttle body.
I would greatly appreciate a step by step walk through to removing the airbox if anyone has one or can type one up without much trouble.
I must be missing something..
Thanks,
Matt
Jbabic 02-03-2003 06:33 PM
no need to remove anything...look at the articles on this webiste
72 four door 02-03-2003 07:19 PM
Gotta drop the motor
Gunter 02-03-2003 07:50 PM
Hi: Read the Pelican Tech. Article under Fuel Injection. It is not recommended to remove the airbox for pop-off valve installation. Why does the throttle body need repairing?
http://www.pelicanparts.com/techarticles/911_pop_off_valve/911_pop_off_valve.htm
SmileWavy
domanows 02-04-2003 04:03 AM
Thank you all so much for the quick responses. I am VERY inexperienced, so I appreciate your patience.
With regards to the throttle body, my car idles up frequently for no reason. That is to say, if I walk away from it while idling, I am afraid I'll come back to a blown engine. The local dealership diagnosed the problem as a worn throttle body. Apparently, their is way to much play where the plate sits inside the Throttle body. Furthermore, the microswitch that keeps the car at idle may also be faulty.
My intention is to remove the throttle body, examine it to better understand what they are talking about, and then decide a course of action.
As for the Pop off valve, I guess I am a more visual person. Since I saw the airbox out and on a bench I guess I assumed it had to come out.
Thanks again,
Matt
wckrause 02-04-2003 05:11 AM
I think I would suspect a bunch of other parts before the throttle body for a wandering idle. Stuff like the deceleration valve, the aux air valve, distributor advance etc.
Whenever I hear the word "dealership", it makes me instinctively grab my ankles. Maybe you could find an independent Porsche mechanic in your area.
jmohn 02-04-2003 07:00 AM
Bill's right, I'm also a novice on the CIS system, but the throttle-body is pretty simple and I've never heard of a problem unless it was "created". There are several items in the CIS system (also, better, known as Bosch K-Jetronic) that could cause the symptoms you describe. For an over-view of the system and brief description of how it works try these sites:
http://www.volvoclub.org.uk/k_jetronic.htm
http://www.students.tut.fi/~hezekiel/bosch.htm
As you can see, there are a number of possible reasons for an "erratic" idle. I would suggest you find a good (non-dealer) shop that is experienced in the K-Jetronic system (shouldn't be too difficult, it was used on virtually every european car of that era). As someone else said, there's no reason to remove the air-box to install a pop-off valve.
Good luck,
Jerry M
'78 SC
john walker's workshop 02-04-2003 07:20 AM
damn dealers. service writers know nothing, but won't hesitate to give advice, you usually can't talk to the mechanic who did the work, and as soon as the mechanics get some experience, they quit and go get a better job, or start their own shop.
Jdub 02-04-2003 07:43 AM
You GO John!
Matt:
I am not sure what "idling up" means, but if you are finding that your engine speed increases for no particular reason you *may* be looking at the deceleration valve for adjustment. Pretty easy.
Find yourself a trustworthy local Pcar mechanic who sees you are interested and wants to learn about the car. Some items you will need to pay a pro. to work on, but then that's how all of us wormed our ways into the hearts of our favorite wrenches (that and donuts and beer anyway!).
This BBS will be a Godsend to you for certain. Right now most everything may seem strange and you will probably get many (seemingly) conflicting bits of advice. I would recommend that you purchase as many manuals on the car as you can (Bentley, Haynes, 101 Projects) and study, study, study. Make a list of what you think is wrong, what sounds off, what standard maint. items have to be performed, etc.
As a miminum, if the car is new to you, change out all filters and the oil.
John
an6drew 02-04-2003 07:52 AM
Noah-
have you been able to remove the CIS system from an '80-83SC without dropping the engine? I'm asking because I'll be tackling the job this weekend, and most people are recommending that completely removing the engine will be the quickest & least frustrating way.
thanks,
Superman 02-04-2003 08:00 AM
Popoff valves are installed with everything still in the car. If you were to really NEED to remove the air bix, it is a tossup whether it's easier to just remove the engine. At a minimum, I would do a partical engine drop where you unhoold rear electrical, get a floor jack under the engine, remove rear motor mounts and just lower the engine a few inches. But I don't think you need to do that. I have never heard of a 911 throttle body problem, but if a throttle body had a problem, it would probably be wear where the throttle plate pivots. The shaft on which the throttle plate sits goes through holes in the throttle body. Just wiggle that, and see if there is play there. I doubt there is. My engine also has a high idle problem, particularly if it sits for a few minutes, engine off, while warm. It's a mystery, but I sure don't suspect the thottle body. More like decel valve or something. My decel valve is disconnected, as many are. I'd agree that sound pads do little more than add weight. I replaced mine, but will not do it again. Useless.
Welcome.
BTW, your car is probably the finest model and year of 911 ever produced.:D
Groesbeck Hurricane 02-04-2003 10:06 AM
Hey Matt,
I'm assuming your in Buffalo, NY. If you are actually around Buffalo, TX drop me a line cause we're practically neighbors. I will try and help you get the little dear out.
I also had the same issue with hunting idle on my '83. I disconnected the O2 sensor and the little dear idles just fine now. Thank you.
And Super is always right. The '83 (especially Targas with wide bodies) have to be some of the best Porsches ever built!!
Gunter 02-04-2003 04:52 PM
Do not go back to that dealership again but ask around for a real Porsche mechanic. Put a request for one on this board, like: Anyone knows a good Porsche mechanic in or near Buffalo? Get a diagnosis before you play with the throttle body, it may be something very simple to fix the idle hunting. SmileWavy
john walker's workshop 02-04-2003 05:18 PM
as for removing the intake system as a unit, the 78 and 79 are fairly easy, and the 80-83 are a *****, due to all the extra crap for the frequency valve behind the intake. i highly recommend doing the 80-83 with the engine removed, or at least dropped down quite a bit. dropping it down quite a bit requires disconnecting just about everything that you would do to completely remove the engine, so why not just yank it.
domanows 02-05-2003 06:20 AM
Gunter, you make a really good point, I have tryed two local shops in the area who claimed they could work on Porsches. Neither knew what they were doing. A friend of mine has been helping me out but I don't want to monopolize his time.
Because none of the immediate upgrades or tune-ups are critical, I would prefer to do them myself under the direct or indirect supervision of someone who knows what they are doing. If there are any experienced individuals in the area, I am willing to compensate them for their time for some hands-on knowlege transfer on getting my car dialed in correctly.
There are a slew of other upgrades that I would prefer to have a shop do, so if any of you folks know of any experienced Porsche mechanics in the Buffalo area, I would appreciate an email.
Thanks,
Matt
Sean Hamilton 02-05-2003 06:55 AM
Matt
Well, from my recent experiences, it may be something as simple as the idle speed set a whisker too fast.
I doubt the AAV is the culprit - plug that thing and say good riddance to it!
Could be the AAR though, maybe the Decel' Valve and/or the WUR - as was my issue, but now thankfully (hopefully) fixed.
Superman 02-05-2003 09:19 AM
Superman is very definitely NOT always right. It get "busted" regularly here. JW is the one who is always right. Matt, please post your plans here when you're considering taking the car to a shop. There are some things I take the car in for too, but they are very few. Some things you'd expect are difficult, are really not difficult. There are mechanics out there worth their weight in gold. But I'm 45 years old and I can count the ones I know on one hand.
Groesbeck Hurricane 02-05-2003 09:29 AM
Superman,
Sorry, I should have justified that remark. "Super's taste in cars is always right! At least, I think so..."
MotoSook 02-05-2003 09:56 AM
The Bentley manual has a pretty good description of how the CIS components work. There are other books that are good also, but they all pretty much say the same. If you understand them, you'll be doing yourself a favor.
The links that Jerry M listed were good info when I was learning (still learning, but not so clueless)
There is a Rennlister, Jim Williams, who has a good CIS website, and he was very helpful when I was learning the things I know about CIS (so was this board).
http://members.rennlist.com/jimwms/CIShome.html
I was completely convinced that CIS was more trouble than it's worth until I understood it. WE will help you learn. Ask a lot of questions.
MotoSook 02-05-2003 01:12 PM
Link didn't work. This show do it.
