Ignition switch removal
I am attempting to remove the ignition switch (83 sc) and I've reached the point of removing the switch from the back of the dash. It will not come out as it's being held by the ignition lock assembly and the Pelican instructions tell you to remove the nut that is holding the lock in place.
I've removed the only visible nut, which is very close to steering assembly but that doesn't do anything to free up the lock. Any suggestions? Thx hughc |
Hi..the nut is actually there to hold the allen head bolt ,which holds the ignition switch in place.
So you have to insert i think 4mm allen and loose the bolt.Then unlock the switch and turn the wheel ,then remove the key,do not turn the wheel again and slide the ignition switch out I assume you have the front 2 bolts as well and the guide plate? Ivan |
Just don'y take that allen set screw all the way out, because it's real hard to get started again due to no room for your fingers.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 10-13-2017 at 04:32 PM.. |
Thank you John and proporsche. You're right, that allen screw does look to be a b..ch to get back in and I stopped just short of doing just that.
Actually I decided to not remove the switch. My original thought was to remove the switch, have it in my hand and test it to see if it might be the cause of my engine quitting for no obvious reason. But after seeing the amount of wiring coming from the switch I decided against it. I'll look at the dwgs again to see if there is another way to do what I want to do. It's very puzzling and taking away from my driving time. ![]() Thx |
The wiring on the back pops off easily. The two screws holding the switch mechanism to the lock allow you to pull the switch off easily.
It's not that difficult 20 minute job.
You can't get a screwdriver in line with the top screw because there's no room, so you have to fiddle with it for 20 minutes.
All the electrical connections are in the back assembly, so you're right not to try and remove the whole thing. And yeah, the top screw is a tight fit, you won't be able to get a screw driver in there. Use a driver bit that's about 1-1/2" - 2" with a small ratchet tool to get to the screw. They sell the tool at most hardware stores. It will be out in a minute.
82 911SC Targa |
Hugh..In case you decide to remove the ignition Lock afterall all you really have to do is inplught ignition back plug like this one on left.It goes back only one way so you cannot fit it wrong.
and this little connector.. other then those 2 front screws and the one back with the nut on it...after it very easy to slide it out Ivan Last edited by proporsche; 10-14-2017 at 08:48 AM.. |
Science is NOT optional
That's what happened to me. I had to do it laying on my back with my head near the pedal cluster. Is there a better way?
PCA member since 1993 |
What is your technique? Laying in the driver's footwell vs. sitting up, by feel, with a mirror or something else?
grateful user
I took a little screw driver and cut it down until I could get to the two little screws.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Thanks. Yes it looks better than removing the entire lock mechanism. Did you just lay on your back to get at it?
Probably one of the most tedious project........
All the above. Remove the driver seat to make room. Make a special short screw driver. Don't get discouraged or frustrated because it won't help you. I have multiple experience dismantling a 911 from bumper to bumper including engine and transmission rebuilds and I find the removal of the two tiny screws holding the ignition switch tumbler very tedious and frustrating. You have to be an acrobat, contortionist, a magician or an artist to get this job done and enjoy it. This is probably the last thing I want as a project. Tony |
I just pull the whole damn thing out.
Wildman Emeritus
Be very careful of the set screw as mentioned. I lost it and had a pita retrieving it with a bent telescoping magnet. Then had to get it back in by cutting a chunk of allen key to twist and using a drop of contact cement to old the screw on the allen chunk. Much swearing involved along with lots of self flagellation for being so stupid.
This and master cylinder are probably the worst jobs I have encountered. I feel your pain; neck, back, shoulders.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
I am my 911's PO
Does the engine restart ok if you turn the ignition off then restart? If so, very likely is CDI lockup, especially if happens more when hot. I had same problem earlier this year and had the CDI rebuilt. No problem since.
1978 SC - original owner 1983 SC - D stock "rescue" track car DECEASED 2015 Cayenne Diesel (rear ended by distracted driver) 2017 Macan (happy wife...) 2016 Cayenne Turbo - tow vehicle and daily drive |
Thx |
At this point the lock housing will come down away from the dash. You should then be able to get the two screws out. I agree that removing the entire housing is faster than fiddling with tiny drivers to get just the switch off. It's a fiddle job. I enlist a pair of small hands and young flexible back that I have around the house to help get the screws out. Wear plastic safety glasses to protect your eyes from all the dirt that will fall down on your face. |
