86 Carrera - cold start issue UPDATE
As some suggested in my OP, I disconnected the CHT plug to see if there was a change to my symptoms. With it disconnected, the car would not start after 4 or 5 attempts but there was noticeable 'rich' fuel smell. So, I re-connected the plug and it started but still had to feather the gas to keep it running...initially for about 20 seconds very rough from the obvious extra fuel in the system then it cleared up fine. I am inclined then to swap out the CHT. To refresh, my initial post the other day began because during a cold start the engine would fire immediately, go to 1K rpms then immediately die...and it would do that repeatedly unless I then applied some pedal to keep it running. After 20 or 30 seconds it would idle just fine around 1K rpms...very smooth idle from then on and when running hot as well. There was a suggestion from one or two who responded suggesting some 'carb cleaner' being sprayed (I forget now the exact terminology of where it was suggested it be sprayed but the intent was to obtain a better idle), but again, the idle is perfect with a hot or cold engine....just that first 20-30 seconds I need to keep catch the rpms from falling off. Hope this makes sense and I continue to appreciate everyone's thoughts and suggestions.
Hi ..i suggest to do one thing at a time..So clean the idle control valve ...then you can test your starting procedure...make sure that when cleaning use a compressor asap to blow the cleaner liquid out...also what was the last time you have check the c/o mixture? fuel and air mix...
Ivan |
Brew Master
Put this with your original thread.
what is your idle speed when warm 800 or 900?
When did you last checked the c/o? Do you have the oxygen sensor plug in or not plug in? Ivan |
Idle is either 900 or 1000 rpm...just don't recall, but again, consistent hot or cold. I just purchased the car so I have not checked the c/o but it is a car that has all records and has been consistently and well services. Oxygen sensor is NOT plugged in and was that way when I purchased it, but in looking at other threads on this forum, it seems that is actually a good thing....most agree it yields better performance (more rich than lean) if one can accept less miles per gallon which I'm fine with.
Try connecting the O2 and see what happens.
ICV may be needed for finer control when engine is (CHT and O2) cold. What year again? agree - one thread is preferable When I got my 87, the ICV drive didn't work, there were small vac leaks, and the O2 was disconnected by the PO who told me it didn't need it. My car was starved of fuel when starting cold (below abt 50 F) until warmed up. I fixed all 3 and the motronic was happy.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
steely ..it is written on top here..... 1986 911 carrera;-)
CHT... ICV... Please expand the acronyms for those who do not know their meaning.
73pcar - does your CHT (cylinder Head Temperature sensor) use a single wire (old) or two wires (newer)? If still a single wire unit, you might want to replace proactively (and see if it helps/addresses your problem) -- It's my understanding that the newer 2 wire unit solves a number of issues the older single wire unit (which came with my '86 carrera and failed in the 1990s) had
Brew Master
I'm starting to understand why Sal strongly recommends an AFR gauge. It would be helpful to know if the car was running lean due to an air leak that would also lean out the cold start mixture. I think in your original post you mentioned that you barely noticed an idle drop when you removed the oil fill cap. Might be time to take a good look at your vacuum lines and clean your IACV.
adias, IACV = Idle Air Control Valve CHT= Cylinder Head Temp Sensor |
ahh, merci
Brew Master
I cleaned and re-installed the ICV...same symptoms as original. I then connected the O2 sensor which has been disconnected since purchasing the car about a month ago...still no difference. So, I guess that might still leave a faulty CHT sensor (unplugging it as another poster recommended only resulted in the car refusing to start and exhibiting a strong fuel smell). Will get to checking the AFR, but if that checks out, then perhaps changing the CHT is the only answer....a few hundred dollar part so I want to be sure. Thanks again for everyone's help.
Still here
Why not replace the ICV ? It’s cheap
Brew Master
Still here
Given cleaning didn’t fix the OP’s issue, are we saying a bad ICV has been eliminated as a possibility ?
