Removing Fuch Centercaps
My right rear centercap is rattling up a storm, all of the rest are tight. I have never removed these, don't really understand what those two little holes are for and figured that I have better write a post before, in typical bloke fashion, I grab the vice grips and employ some brute force and ignorance.
So how do I figure out the problem, remove, etc?
85 Triple Black Cab <SOLD>
01 Triple Black Waterpumper
Old 02-04-2003, 06:07 PM
R22tech's Avatar
I take them off with my finger nails slowly and carefully, however, there is a tool for this. DO NOT USE PLIERS- you will make those holes show up like sore thumbs on a supermodel! You could probably make one yourself out of something like a clothes hanger made into a "V' with feet. Or: you could make an incomplete square and "thread" one end through both holes and then use two pliers to pull both ends of the hanger. The caps pull straight out.
85 Carrera Targa (sold!)
03 Dodge Ram 1500 HEMI
Old 02-04-2003, 06:41 PM
Method one is to bend a coat hanger to look/work like the special $22 tool to remove the caps. Insert into holes and pull the cap off. Method two is remove the wheel and push the cap out from the inside.
Old 02-04-2003, 06:43 PM
Irrationally exuberant
ChrisBennet's Avatar
The cap is made of two pieces. The black part you see (the "cap") and a yellowish "backing piece" that fits into the hole in the wheel. Pulling the cap off from the sides (with your fingers) will tend to pry the front of the cap off the backing piece. BTDT. Use a hammer handle to tap the cap out of the wheel from the back.
The Fix: Looking at the back of the cap you'll see 3 (?) little studs sticking out. The studs protrude from the back of the black "cap" through the backing piece. The ends are squished flat (like a rivet) to hold the backing piece to the cap. Re-flatten these studs to tighten up the cap and stop the rattling.
-Chris
Old 02-04-2003, 07:10 PM
Thanks guys, I will try it out tonight
Old 02-04-2003, 09:04 PM
Send a message via ICQ to old_skul
I use the cap retainers bought here at PP. They have three allen screws in a ring that fits inside the inner rim of the cap - and when you tighten them up, there's no rattle, and no disrespectful punk making off with your fancy caps, either.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 02-05-2003, 09:02 AM
RETIRED
Joe Bob's Avatar
The allen's are nice, but require the wheel to be pulled to remove them. If you race in AX or DEs, that can be a PITA, some race techs make you remove them. But if you use race tires not a problem.
The backs may be pinched IN as well, a little outward pull with a channel lock plier will tighten it up. Also a little dab of clear silicone along the back edge of the cap will help.
Old 02-05-2003, 09:38 AM
When mine rattled it was the 2 pieces of the cap rattling, not a loose fit in the wheel.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-05-2003, 09:45 AM
