speedking's Avatar
Removing Clifford Car Alarm Parts
I removed some more uneeded old car alarm parts from my 1979 SC today, which had been cluttering up the frunk. The car has one of the Clifford brand units that were sometimes installed by dealers, and it was inoperative when I bought the car, but still in place. I'm sharing in case someone else wonders what these parts are and needs encouragement to get rid of them. When searching for alarm components (there are surprisingly many), some giveaways are: 1/4 inch or 3/8 inch heads and wiring that looks sloppier than Porsche's. The unlabeled metal box seems to be the movement trigger; it has an LED and it rattles/ticks when touched as though there is a spring in it. The other thing is a "Siebel Junior" air horn. The second pic shows it installed next to the spare tire. Good riddance!
Old 09-03-2017, 03:41 PM
LOL just did that on my 83....did you get the keypad too?
Old 09-03-2017, 04:43 PM
gearhead
Just finished this on my 74 today. I'll be updating my thread later...
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-03-2017, 04:46 PM
speedking's Avatar
I did! There was a nasty hole in the left dash panel where the keypad was, but I scored a replacement panel at the Hershey PA swap meet last year. Replacing the panel required removing the driver seat and lying on my back, but otherwise it was straightforward. Removing that ugly keypad felt great!
Old 09-03-2017, 05:40 PM
Burnin' Rubber
Koizumi's Avatar
Yours looks comparatively neatly installed. Mine was installed by a junior high school kid. I had to keep the keypad because the installer cut a very very badly done hole with a hacksaw behind it. There is nothing I can find that will cover up the hole correctly. The ignition surround had to be cut as well when the Clifford keypad went in.
Cheers
Old 09-03-2017, 05:41 PM
Earthling
Brian Cameron's Avatar
Our 79 SC has a clifford which still works fine, the remote also does keyless entry. There is a keyboard on the dash but what's it for? i mean, if the remote enables / disables the alarm, why do you need the keypad? Is it an override in case the remote is dead or missing?
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 09-04-2017, 12:08 AM
David 23's Avatar
I'd love to have some detailed instructions on how to remove a working Clifford alarm. I am afraid to just start pulling out wires.
1979 911SC 3.2 SS Custom Backdate Hot Rod
1972 911T, 2.7RS Spec
Beck 904 Carrera GTS /3.6
2023. Macan
Previously owned several 911 models since 1975.
Old 09-04-2017, 06:53 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Just get in there and start looking around. Like speedking says there is a world of difference between aftermarket and old Porsche wiring.
Main thing is to find the kill point. If I remember correctly it was the yellow wire that leads to the starter assy from the ignition key cluster. They cut the yellow wire and the alarm system is wired to each end.
If you figure that out, you can bypass the alarm system and take the not needed stuff out at your convenience.
This is from 15 year old memory so the comment may be at least worth what you paid for it.
1981 911SC Targa
Old 09-04-2017, 07:14 AM
gearhead
In the corner of the frunk by the passenger side hinge.
1974 914 Bumble Bee
2009 Outback XT
Old 09-04-2017, 07:32 AM
Tags
clifford alarm
