Euromeister 8s or 9s
Hey guys...83 SC coupe....I'm looking at putting on a set of Euromeister 17s....gonna go with 7s (et 23.3) in the front but my question is should I go 8s (ET 10.6) or 9s (ET 15) in the rear. I don't want issues with having to roll fenders or messing with spacers and just wondering if the 9s will fit or if the 8s are better for the rear. Looking at putting on 255/40/17s for tires in the rear. By my calcs it seems the 9s will bump out the rim and tire edge about 0.5 inches from the 8s. Anyone running this setup?
Old 09-01-2017, 10:57 AM
911SC Tinkerer
merlinfe's Avatar
All depends on what ride height you are at and the state of your suspension. Ask yourself some questions:
Are you running on old shocks/ suspension bits? Do you corner the car hard on these or do you take it easy?
Do you "need" 9's? Can you fit 255s on the 8s and be happy?
If you ARE going below Euro ride height (whatever that means at this point), do you feel like rolling the fenders?
All that said, I am running 9s now and would go either way if I had it to do over again. I'm using 245/40/17 tires on the 9s and haven't had any issues with rubbing at the stock '83 "Euro" ride height. YRMV. The 17" Euromiesters with tires are heavy enough that you feel the difference when accelerating which is something to think about. I would have gone with 16s if the tire selection were better, but this is the world we live in.
Good luck.
-Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 09-01-2017, 11:42 AM
"All that said, I am running 9s now and would go either way if I had it to do over again. I'm using 245/40/17 tires on the 9s and haven't had any issues with rubbing at the stock '83 "Euro" ride height. YRMV. The 17" Euromiesters with tires are heavy enough that you feel the difference when accelerating which is something to think about. I would have gone with 16s if the tire selection were better, but this is the world we live in. "
Steve- That's what I'm really afraid of also going with cast wheels....hearing that you can tell with acceleration is definitely a factor to consider......current setup is 83 BBS RS 16s....forged and light. I really want to be able to throw some Michelin Super sports on, but with the 16s...no go
Old 09-01-2017, 01:16 PM
Angry
Good luck.
-Steve
Old 09-01-2017, 01:19 PM
Have you seen the Euromeisters in person? They had one feature I wasnt really fond of and that is the lip of the wheel has very lightly machined ridges to give them the anodized look. I ended up getting rid of them in favor of the real thing after a few months.
1982 911 Targa, 3.0L ROW with Webers
Old 09-01-2017, 01:37 PM
9"x17"ET15 with 255/40-17 will fit all SC and Carreras with no problems, even on below Euro ride height.
I'm running 9"x17"ET16 and 255/40-17 with 25mm spacers on my lowered narrow body Carrera...
1985 928 S3, 5-speed
1987 Carrera, current project
2012 Jaguar XF 5.0, Wife's d.d.
2009 Boxster,sold, 2000 Boxster, sold, 1995 993, sold, 2004 Maserati, sold, 2000 996, sold, 1971 914, my college car, 1966 911, sold way too cheep, Lots of VW's...
Old 09-01-2017, 01:43 PM
sugarwood's Avatar
I have the following with no rubbing
F: 205/55/16 (7”)
R: 245/45/16 (9”)
1986 Bosch Icon Wipers coupe.
Old 09-01-2017, 01:45 PM
I have a pair of 8's and also of 9's. If you have access to both sizes or can view good pictures of both you will see that the added width of the 9's must be on the inside because with the exception of the valve stem placement they appear virtually identical. If the wider appearance of a 9" wheel over that of an 8" is what your looking for, actually the Euromeisters will look the same.
Old 09-01-2017, 02:00 PM
Bill Verburg's Avatar
Don't believe everything that you hear, Most people would be hard pressed to feel a 10#/wheel delta. There is a penalty for extra wheel or tire weight, more so for tire weight even more so for increased tire OD.
Far more significant is the tire OD and even more pertinent is the tire revs/mi, these specs vary quite a bit for tires of the same nominal size but on average
225/50 x16 revs/mi is ~839
245/40 x17 revs/mi is ~842 less than 1% better acceleration
255/40 x17 revs/mi is ~834 ~ 1% worse acceleration than 225/50 x16
225/50 x16 & 245/40 x17 will fit fine on an SC w/ 8ET10.6 wheels
255/40 x17 fits fine on an SC w/ 9ET15 wheels
205/40, 205/45, 215/45 x17 all will fit fine on 7Et23.3
for best performance most of the above want a wider wheel 7.5 or 8 in front and 9.5 in back
Bill Verburg
Old 09-01-2017, 02:03 PM
Cars and Cappuccino
tdw28210's Avatar
This is true. I had mine hydro-blasted to get rid of the ridges.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 09-01-2017, 02:18 PM
911SC Tinkerer
merlinfe's Avatar
Just sharing what I observed Bill. The tires are slightly heavier when you go from 16s to 17s. The wheels are slightly heavier going from Fuchs to Euromiesters. The difference in acceleration wasn't Earth shattering, by any means, just a bit different and more than I was expecting.
OP do what you want. You won't be disappointed with either the 8 or 9 inch wheel as they look the same from outside the car, and in my humble opinion, they look pretty good on the car.
-Steve
-'83 911SC Coupe
Old 09-01-2017, 06:18 PM
Porsche Crest
Great input! I think if I have my choice and they fit no problem on the euro height/minus setup I would definitely want to go with the 9s and put on the 255/40x17s
Old 09-01-2017, 09:55 PM
After just finishing the turbo tie rod upgrade and now with all this talk on the wheels....I am definitely just going to bite the bullet and refresh the whole suspension.....new inserts, bushings, ball joints, torsion bars.... the whole lot....man this rabbit hole is crazy! Thanks for all the input on this guys....keep it coming if you have other suggestions you think would be good.
Old 09-01-2017, 10:20 PM
83 911 Production Cab #10
JJ 911SC's Avatar
I'm running these with no rubbing @ 24.75"
P205 50ZR 17 93W Yokohama AVS ES100 on Euromeister 7 x 17 (offset of 23) with a 32mm Weltmeister Wheel Spacers
P255 40ZR 17 94W Kumho ECSTA ASX on Euromeister 9 x 17 (offset of 17) with a 50mm Weltmeister Wheel Spacers
Who Will Live... Will See
Old 09-02-2017, 03:59 AM
I use 225/45 & 255/40 x17 on 8 & 9.5, that's a great combination especially w/ a little more motor, still ok down to a 3 liter, though the 245/40 gives a little more zip and doesn't give up much grip. on 7 & 8 x17 w/ smaller motor I'd probably go w/ 205/45 & 245/40 RE71.
Bill Verburg
Old 09-02-2017, 06:32 AM
On an SC/Carrera that's just not credible, you must have 930 body work
Bill Verburg
Old 09-02-2017, 06:33 AM
Seriously!!? This seems way too wide.....I ran the numbers and the distance from my outer hub to the fender lip is 4.125 inches measured horizontally.....with your setup it would seems like the outside of the tire would sit 6 inches out from the hub!
Old 09-02-2017, 12:50 PM
JJ 911SC's Avatar
Not for a wide body... The main point is that there is no rubbing.
Old 09-02-2017, 01:23 PM
That makes way more sense! Great look! Thanks for the pictures
Old 09-02-2017, 01:40 PM
JJ 911SC's Avatar
Here is some more:
Finish Product...
Amazing what a $9 spray paint can will do. The center and lug nut were black
Front 7x17 Et 23 (16.5 Lb), 80mm spacer/adapter combo with 205/50 R17
Rear 9x17 Et 15 (18 Lb), 70mm spacer/adpter combo with 255/40 R17
The tire were the same on my Cup wheel so no change size wise
Old 09-02-2017, 01:48 PM
