Brakefluid Overflow Exit Point
Hi All,
I just discovered a small leak just behind the front oil cooler on my 82 911SC Targa. I located a small clear tub that looks to be a drain for some type of fluid. It does not have a smell and looks to match the color of brake fluid. I did just replace the rear pads, so tis would make sense. Is that where the line terminates?http://forums.pelicanparts.com/uploa...1504651247.jpg |
I just bled mine and don't remember any hose being on the bleeder screws nor have I seen overflow lines ever on calipers. So unless someone added that I would say its something else.
Brake fluid definitely has a smell. Open a bottle if you need to refresh your memory.
Thought I had a rear main (flywheel) seal but thankfully it was just the clutch slave cylinder leaking brake fluid into my bell housing. Collect a bit to smell it if it's still leaking. |
The brake fluid reservoir overflow exits from a clear plastic tube at the front of the car. You can follow the overflow line from the reservoir to the exit point if you lift the frunk liner out of the way.
Can you show another pic from a wider angle? |
I've seen some lines exit behind the front bumper, so if a cooler was mounted there, well that's that. I searched the forum and found some exit elsewhere but this seems MY dependent. |
Yes, this is the end of overfill-drain-tube. got the same install on my SC.
when filler is up full and you work on brakes (e.g. pad change) and push back the caliper pistons pushing back fluid, the reservoir may overflow. so allways check fluid level first, and if necessary drain some fluid first. when bleeding brake lines by pressure, allways block off drain line with a tight clasp!! |
| All times are GMT -8. The time now is 03:23 AM. |
