cab713's Avatar
Brakefluid Overflow Exit Point
Hi All,
I just discovered a small leak just behind the front oil cooler on my 82 911SC Targa. I located a small clear tub that looks to be a drain for some type of fluid. It does not have a smell and looks to match the color of brake fluid. I did just replace the rear pads, so tis would make sense. Is that where the line terminates?
Chris
1971 911E (Tangerine/Black)
1987 951 (Guards Red/Black)
1985 928S Euro (Prussian Blue/Blue)
Old 09-05-2017, 03:41 PM
I just bled mine and don't remember any hose being on the bleeder screws nor have I seen overflow lines ever on calipers. So unless someone added that I would say its something else.
Old 09-05-2017, 03:44 PM
Brake fluid definitely has a smell. Open a bottle if you need to refresh your memory.
Thought I had a rear main (flywheel) seal but thankfully it was just the clutch slave cylinder leaking brake fluid into my bell housing. Collect a bit to smell it if it's still leaking.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 09-05-2017, 03:55 PM
76 911S Targa
The brake fluid reservoir overflow exits from a clear plastic tube at the front of the car. You can follow the overflow line from the reservoir to the exit point if you lift the frunk liner out of the way.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 09-05-2017, 04:31 PM
steely's Avatar
Agreed. It's nowhere near the oil cooler.
Can you show another pic from a wider angle?
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 09-05-2017, 07:17 PM
The OP could have a front cooler other than the one commonly found in the wheel well. If so, this may be the brake fluid over flow tube. Yes, a wider angle shot would help.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-05-2017, 07:47 PM
El Duderino
tirwin's Avatar
This. On my '83 the exit point is on at the front left (driver) side. It is near the washer fluid reservoir. You can find this point relatively quickly when you use a power bleeder and forget to pinch off the overflow tube at the reservoir.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 09-05-2017, 08:42 PM
steely's Avatar
Good point - my line is under the fuse panel on the drivers side so I naturally 'assumed' the OP's oil cooler would be in the fwd RH/passenger side wheel well (opposite side) and thus not close to ea other.
I've seen some lines exit behind the front bumper, so if a cooler was mounted there, well that's that.
I searched the forum and found some exit elsewhere but this seems MY dependent.
Dan
Venetian Blue
Old 09-05-2017, 11:00 PM
Flojo's Avatar
Yes, this is the end of overfill-drain-tube. got the same install on my SC.
when filler is up full and you work on brakes (e.g. pad change) and push back the caliper pistons pushing back fluid, the reservoir may overflow.
so allways check fluid level first, and if necessary drain some fluid first.
when bleeding brake lines by pressure, allways block off drain line with a tight clasp!!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 09-06-2017, 01:43 AM
