Irhmsd's Avatar
Finicky 915
Sometimes have trouble shifting from 2 into 3. Other times it shifts just fine. Today, we drained out some gear oil and put in a quart of Lucas. Not a lot of difference. No grinding, just tough engaging into 3rd. Thoughts? She is mated to a 3.2 but I doubt that makes a difference. The car, and trans, is from a 1974.
2013 Speed Yellow 991 Cab
1974 Silver 911S Targa 3.2
1997 993 Cabriolet
1958 356A Sunroof Coupe
2002 Rover P38 Borrego
Old 09-07-2017, 06:12 PM
Not as it seems
juanbenae's Avatar
syncros & dog teeth at the worst. do you know the miles on the gearbox?
if you've not adjusted the clutch yet try that, maybe a new cable. they do stretch leaving a half gone clutch disk seem more tired due to lack of adjustment. .
there are a number of shifter linkage bushing that can be tired/worn, or less than lubed/adjusted that will make things seem worse than they actually are if neglected or are out of whack.
research some of that and tell us what you find out!. or it's syncros & such
Old 09-07-2017, 07:01 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 Likey Synchros and Dogteeth.
Try double clutching, if this cures it then for sure it is the synchro bands/slider
'85 Carrera Targa
PCA/POC
Old 09-07-2017, 07:30 PM
