cycling has-been
Help with wiring Blaupunkt.
This is the back of a 1976 Munster - euro option from a Stuttgart dealership in 1976.
I sent the unit to Radioman for a rehab, installed it and got it working. Problem is that I don't have any lights - no dial backlight, no power indicator, no signal strength indication. Could the circled male spade terminal have anything to do with the lights? Radioman said it's not a ground - the unit is grounded to the chassis via the metal 'C' clamp on the fronk wall. Thanks, Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 09-08-2017 at 10:40 AM.. |
Administrator
Hello Bill,
I found an earlier thread where this is discussed; I'm sure our members will also chime in and help out. Best of luck. Blaupunkt Wiring and Fader Control |
Fb = M/S
Pretty sure that's a ground. I have a manual for a Blaupunkt CR 3001 and it shows a similar spade connector on the back of the radio and amplifier and it is a ground.
1981 911SC, Guards Red/Black Leather 2014 Audi A6 Prestige, Phantom Black Pearl/Black Leather, Black Optics 2017 Tesla Model X Gone but not forgotten: 1969 Datsun 2000, 1973 914 1.7, 1976 912E |
Eng-o-neer
Maybe a bulbs burned out? To be clear, you hear the music, but are just missing lights?
![]() Are both of those posts near "+12V" connected to power? At first I thought one would be the antenna, but I suspect that's plugged into one of the round holes. The spade is connected to the chassis, and the chassis is ground. I suspect that spade is an "extra" ground. |
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Bill,
Here is the back of a couple of units, not too different from yours except your unit is not stereo (you have only one connection for the speaker) You did circle the the ground spade in your photo, and depending upon your installation, the unit should be grounded directly with that connection. The unit may ground itself with the "c" clamp, but it may not be consistent. ![]() ![]() You see the "ant" spade next to the "12v +" spade. Be careful not to ground the "ant" spade to anything. That is used as a switched power source for a power antenna otherwise you run the risk of shorting out the unit.
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Heck, I’m only 5 not 71!
That spade connector is a ground connector. If that spade connection had an insulator between the case and frame then it would not be a ground connection.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
cycling has-been
Thanks all.
I suspected it was a ground, as it was un-insulated. Radio (mono) works without it, but I'll wire up a ground just to be safe. I doubt that all three bulbs are burned out, but after being idle for 30 plus years, it's very possible. The shop said they worked when bench tested.(dial backlight, power indicator, and signal strength). Any suggestions as to improving FM reception? Thanks again, this board is amazing. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
cycling has-been
...and for those who have never seen, or heard of the Munster....
- cute - huh? Bill K Oh yeah, excuse my ignorance, but what's a '7 pin DIN connector adaptor', and the had those back in 1976? ![]()
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 09-08-2017 at 05:33 AM.. |
Vintage Owner
The DIN connector is used to connect the tuner part of the radio to the amplifier portion. It can be wired so you can install a socket to wire in an auxiliary input (iPod, MP3, etc.) if desired. If you look carefully, you'll see small wires connecting the terminals in the plastic plug.
And definitely connect that ground lug in the back of your radio.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Cars and Cappuccino
Got sorta the same radio for my RSR-ish backdate build. I dig the clean face on the radio. I am going to install mine with a Tranzit bluetooth adapter (via the DIN plug - I think- can't recall). Here is the radio and adapter.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Pre-amp
Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
