			 Armed Bastard
				2.7l with K26 Turbo Project
			Hi everyone,
				I thought I'd share what I've been working on for the past few weeks. First, a shot of my car pre-project: ![]() And here's a shot of the current status of the project: ![]() The basics are as follows: I'm using a K26/6 turbo from a 944 turbo, mainly because I had the turbo but also because it seemed to fit the 2.7l 911 engine pretty well. I'm no expert on reading a turbo map, but the motor seemed to fall into the right areas on a map I found online. Headers are used OBX that I got a few years ago. They're in nice shape and fit up perfectly. Ignition and fueling are controlled by the ms3/ms3x I already have in the car. Ignition is provided by six LS2 truck coils that I've mounted on the valve covers. You can see how I fitted the coils in this picture: ![]() Muffler a Magnaflow oval unit that I got from Amazon. It seems really nicely constructed and TurboKraft uses the same brand, so I think I should be in good shape. ![]() I think I'm about ready to install the motor and try to start it up. Possibly will happen tonight. I'll post more if anyone is interested.
	Damion '77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition  |
			 3 restos WIP = psycho
			Interested!
			Sent from my Nexus 6P using Tapatalk
	- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930  |
			You better get some more meat in the back of that car.
	72 911 Although it is done at the moment, it will never be finished.  |
			Sweet! Nice garage too
	1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS  |
			Nice project. Keep posting
	Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk  |
			 Registered Minimalist
			Super cool project.  Can you tell me more about your intake setup?  Was the motor rebuilt and what cams, p/c, and intake/exhaust size are you running to allow the late model intake setup?
			I like your fan too is it just paint? Would like to see more details on the ignition mount on the valve covers.
	Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads  |
			Sweet! How is the drain configured? Are you running an electric scavenge pump?
			Love it!
	2007 GT3 1982 911SC 1998 Integra Type R  |
			 Armed Bastard
 The fan and intake are both cerakoted. It's a two-part ceramic finish that is popular for firearms. I found it works great for car stuff as well. It's tough as hell and crazy thin. I'm draining the turbo directly to the sump plate using -10an PTFE hose. If I end up with problems with that arrangement, I'll probably go with an electric scavenge pump.
			 Armed Bastard
			Well... after several months of screwing around - IT IS ALIVE.
			And it is FAST. I got super frustrated trying to get the car to run right, and ended up buying a chinacharger off of eBay. It’s a fake gt3076r, with journal bearings instead of ball bearings. Turns out I had simply mixed up two injector wires, so only four of the six injectors were firing! I swapped the wires and took the car out today. It was... shocking. It doesn’t really come onto boost until around 3500 rpm, but when it hits... wow. Third gear hit so hard I thought the front wheels were going to come off the damn ground. I think bigger torsion bars are going to be necessary. I’m running 10 psi, btw.
			 I would rather be driving
			Glad you have it running...  And that its fast.
			Tune carefully before you really get into boost. The 2.7 case will not tolerate tuning sins.
	Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks  |
			nice work...i like the way you mounted your coils...very tidy.
			regards, al
	[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/  |
			We're gunna need some video... yeah with mic mounted on the bumper. :-)
			 Banned but not out, yet..
			Yup, need to see it in the wild.
	An air cooled refrigerator. ‘Mein Teil’  |
			 Armed Bastard
			Anyone have any idea why my idle is so rich? I have the idle cells on the VE table down to around 0.3-0.5, but the car is still idling around 11.5:1. I'm guessing I have some setting wrong somewhere, but I'm not sure what I need to change. Any thoughts? Where to start, perhaps?
			Do you want pulled head studs?  Because this is how you get pulled head studs.
	Seriously - Cool project. I guess stock compression on a 2.7 is only ~8.5:1, right? Seems like a good candidate for a turbo if you can tune it well to prevent the case from coming apart...  |
			Either your injectors are too big or your dead time is wrong or both.
			 Turbonut
			Maybe stupid question but you do have vacuum hose connected to the ECU from the intake manifold right?
			Also if you run out of tuning space in VE table I suggest to lower req fuel constant (injector size constant) and adjust VE table accordingly.
	'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche  |
			Here is a long and meandering but filled with good bits thread on the topic of non 930 turbo 911s
	77 3.0 build. - Tribute, Track, or Hot Rod - PFA  |
			 Armed Bastard
 I have dead time set to 1.200 msec, which I think came from a bunch of digging around and looking at data for the Siemens-Deka injectors. But I could be 100 percent wrong with that number. Injectors I'm using (current injector is on top):
