SC to RSR coil over suspension set up and body work
Continuing with I started showing last week....
The suspension set up for my SC to RSR project is starting to come together. Most of the parts are in... ![]() Going with the true RSR Coil Over suspension. We also did the proper reinforcements on for the mounting points. In the rear we cut through the rear firewall to insure the mounting points were welded correctly. ![]() Front suspension done with the same detail..
further reinforcements
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
awesome! good to see all the extra support
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
that looks great....did you fab the red parts? Curious why you didn't go full monty w/ front camber boxes alongside all the other work.
Mat P 1988 911 Carrera |
Mat, in case you refer to me/my picture..., this is just one part of all the possible RSR reinforcements, selected for "PassionDriven" to add up to his done work.
edit, here's a classic reinforcement:
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 09-12-2017 at 12:08 AM.. |
Flo - I didn't even realize you weren't the OP. sorry! I do like those reinforcements.
Flo, do you sell those pre-made reinforcements?
64 356C (project) 65 GT40 by Superformance 67 912 Coupe (currently upside down, being restored) 68 912 Targa (project/driver) 71 911T (project), 76 911 GTL-to-be, 86 944 spec racer |
