CDI thingy failed / Options?
OK - the CDI unit has failed on my race car (2.7 litre with webers).
What are the replacement options - can you still buy them or are there better aftermarket versions?
Cheers - Ryan (he who hates all things electrical...)
Old 02-04-2003, 10:34 PM
Senior Member
Zendalar's Avatar
Replace the whole ignition system. MSD makes excellent (so i have heard) ignition systems, but also Allison/Crane has proven (in my case) to be pretty good system.
Allison/Crane with optical pickup is cheaper than MSD and for 150$ you would get performance coil to match the ignition box.
Projects:
911 -72T EFI "964-look" "Smoky"
914 -71 1.7 D-JET "Rusty"
Old 02-04-2003, 11:16 PM
AirCooledExcellence's Avatar
Ryan,
Might be worth taking it to an auto electrican might be fixable?
Cheers
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 02-05-2003, 01:18 AM
Ryan;
I recently had mine rebuild by our host. Cost about the same as an aftermarket unit and is as good as new.
Cheers,
Todd
Old 02-05-2003, 02:06 AM
bigchillcar's Avatar
Ryan (good name, brother),
Did yours start having problems by intermittently making a very loud squeal that you could hear while driving? During very cold weather the past few weeks, mine has occasionally squealed loudly when cold at least...haven't heard in about two weeks, thankfully.
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 02-05-2003, 06:15 AM
Thanks all - the unit has been sent to the elec to see if it is fixable.
Z - Can't replace thre whole iginition system as I also use the car for hisotoric rallies and it needs to be reasonably "period" correct.
Ryan - Haven't run the car since last nov, has been sitting at mech's shop having carbs rebuilt. Took it out for a test drive and it want kaput (probably not due to cold - I'm in Sydney and in the midst of a great summer) - Ryan
ps: First race of the season in about a month now.....
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 02-05-2003, 02:19 PM
A Quiet Boom's Avatar
MSD
I've got the 6AL with rev limiter, tach adapter, and the programmable timing computer, worth lots in terms of drivability and power. And yeah those are Zeniths with 36mm venturis on a 3.0.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 02-05-2003, 08:53 PM
Bird. It's the word...
Fishcop's Avatar
Ryan, I've got the Crane XR700 optical ignition on my '69. If you can get it past scrutineering (sp?) you'll find it very worth-while.
Cheers
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 02-05-2003, 09:02 PM
CamB's Avatar
I ran an MSD in the '69 while it was still a 2 litre. It made up for the dodgy Marelli distributor's NLA consumables (rotor and cap). It idled and ran beautifully.
I now run it in the BMW, which also idles beautifully. In fact, it didn't foul the plugs when inadvertently run at about 10% CO for 10 mins while being tuned...
MSD (or Crane) = cool.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 02-09-2003, 01:59 PM
pardon me for jumping in on this thread, i have a question for fishcop ....
are you running your xr 700 through the bosch cdi unit? and/or with the crane cd unit? what coil are you using? and how is your tach connected?
i'm using the xr700 on a '67 2.0 in a 70 914-6. i have the crane box running through the bosch cdi and the bosch blue coil.
i'm chasing erratic running and i'm wondering if i have the correct coil.
thanks!!
doug waters
doug waters
70 914-6
dougwatersfotos.com
http://www.flickr.com/photos/dougwatersfotos/
Old 02-10-2003, 03:26 AM
Senior Member
Zendalar's Avatar
No rough running here without the Bosch box. Straight from the XR700 unit to Allison/Crane high power coil.
Projects:
Old 02-10-2003, 03:48 AM
Early_S_Man's Avatar
Porsche Crest
Doug Waters,
The Bosch Blue Coil is MOST ASSUREDLY NOT the correct coil to be using with a Bosch CDI unit!!! Using that coil can destroy the CDI unit if/when the coil shorts out internally!
The two most common Bosch part numbers for the correct CDI 'Ignition Transformer' [factory speak for coil] are 0.221.121.001 and 0.221.121.006 ... former is the '70 - '73 part with '1', ''4', and 'A' terminals, and the latter is an SC coil with 'A', 'B', and '4' terminals ... with the 'A' and 'B' primary terminals offset on one side about 1" apart.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-11-2003, 10:14 AM
aahhh ....... oops!!!
warren and zendalar, thanks for the info!! i must've gotten some wrong info!!
thanks again!!
doug
doug waters
70 914-6
dougwatersfotos.com
Old 02-11-2003, 03:27 PM
Author of "101 Projects"
Wayne 962's Avatar
Right-o, you can't use the blue coil with the Bosch CDI unit. You can use the Bosch blue coil with the MSD unit. We do have these Bosch Units rebuilt - cost is about $150 or so, and they come with a warranty too...
-Wayne
Old 02-12-2003, 04:44 PM
pwd72s's Avatar
THat's good news Wayne...just looking at the price of a new Bosch CD box can cause heart failure...
Old 02-12-2003, 05:05 PM
