6771911esses's Avatar
Q: 2.4 cis car with 2.7 cis will the 2.4 fuel filter and accumulator work.
I am installing a 2.7 cis in a 73.5 cis 2.4 car. Does anyone know if the 2.7 will run with the 2.4 fuel accumulator and fuel filter set up? I am trying to keep that part of the car "original" unless absolutely required to change over to 74 + set up.
Old 09-12-2017, 04:14 PM
Functionista
manbridge 74's Avatar
I am thinking yes with maybe some slight re-configuration of plumbing.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-12-2017, 04:27 PM
HarryD's Avatar
FWIW, the 1973.5 CIS fuel filter is NLA.
You would have needed to go to the later setup anyway. Should be no problem.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-12-2017, 06:21 PM
Functionista
It's likely already been retrofitted with updated parts. I was able to finagle a later larger Bosch filter that was a turbo part back when I was running CIS. More capacity is only real advantage. Lot of configurations possible.
Jeff
74 911, #3
Old 09-12-2017, 06:27 PM
