Difference between 911/81 & 911/85
Hi everybody,
I'm facing some problems to register in Switzerland an US imported 1977 911s.
The registration office argue about the fact that the 911/85 engine that has my car isn't the same of the 911/81 sold in Switzerland at that time. The problem apparently concern the specigication about pollution and noise.
It's possible to find somewhere if the two engine have the same spec?
My engine number start with 627(3136), the european one's started with 637(xxxx).
Tks a lot for your help
Max
Old 09-14-2017, 03:42 PM
Registered Minimalist
75 911s's Avatar
Type 81 is a EURO ROW engine
Type 85 is the US engine.
Ironically, your US engine is the lower smog engine as it was originally equiped with an Air pump, EGR filter, and Thermal Reactors.
You can pick up the Red book and take that to the committee. The engine itself (I THINK) has the same exact specs. The difference is in the add-on devices mentioned above.
The specs for both type 81 and 85 are as follows:
90mm bore, X 70.4mm stroke
2.7 ltr, 2687cc
8.5:1 compression ratio
k-jetronic fuel injection
165 hp at 5800 rpm
176 ft lbs torque at 4k rpm
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-14-2017, 04:39 PM
I'd get the spec book. The numbers change but the internals are the same. Cam settings may be different or the exhaust can be different.
Some of the 77 euro s I've seen were without power brakes, no helper spring on the clutch arm, 8.0 CR for 150 horses, with T CIS cams.
Spec book will tell you
Bruce
Old 09-14-2017, 04:48 PM
Hi, here are few scans related to specific engines:
Hope this helps
Stan
ps. if u need I have new Tech Spec book and Owner Manual for 77 911 for sale
Old 09-14-2017, 07:30 PM
IROC's Avatar
My car's original engine was a 911/81. In my 10 years or so of messing with that engine, I never found a difference between it and a US-spec engine.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 09-15-2017, 04:03 AM
4flyboy's Avatar
You guys are incredible fountains of information.....I am amazed
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 09-15-2017, 06:55 AM
Guys tks a lot, this help me so much!
I'll have a meeting with the registration office soon.
Finger cross!
Have a nice w-e
Max
Old 09-15-2017, 08:31 AM
