-   -   Air Flow sensor on a CIS (http://forums.pelicanparts.com/porsche-911-technical-forum/970287-air-flow-sensor-cis.html)
JSZ 09-15-2017 06:29 AM
I have a 1982 911, in which the adjusting key access port of the air flow sensor was broken. It appeared to have threads which the plug would screw into. Does anyone have the thread size for the adjusting key port?
Thank you, Jeff
HaroldMHedge 09-15-2017 07:29 AM
I'm not sure of the thread size but this plug was installed to prevent adjustment of the CO mixture for emissions. Earlier CIS cars have a rubber plug with an extension to plug the hole.
Here's a good thread on the plug, see post 11 for a picture of the replacement plug.
Plugging the CIS Mixture Adjustment Hole?
