-   -   Backdate hood latch idea (http://forums.pelicanparts.com/porsche-911-technical-forum/970314-backdate-hood-latch-idea.html)
SpyderMike 09-15-2017 08:59 AM
I am doing an all steel backdate of my 1985:
http://forums.pelicanparts.com/porsche-911-technical-forum/819396-so-how-backdate-project-starts.html
Doing research on the hood latch situation I have the following options:
a. buy a long hood and have it modified to relocate the upper latch location to the short hood location
b. have my short hood modified with an extension to be a long hood
c. get a fiberglass hood that is made for this backdate
d. buy a long hood and replace the nose piece of the car to the long hood style
e. buy a long hood and find a different way to latch it.
I don't particularly care for visible hold downs as this is not a RS tribute or hot rod that I am going after. So for the latch, I need to come up with something to fit in this space. I wanted it to be fairly bolt on with minimal cuts to the car. It has to be simple. I want two latches for backup safety.
http://forums.pelicanparts.com/uploa...1505176588.jpg
I found some micro latches for hotrods that just might work...there is enough space there to come up with something that will work.
SpyderMike 09-15-2017 09:00 AM
So I spent about 3 hours mocking up the latches and trying different locations.
I wanted two latches and to have them spread out on either side of the original latch location
The actuating arms are long and I first tried to located them to be in the indent areas of the hood either side of the original latch plate:
http://forums.pelicanparts.com/uploa...1505490344.jpg
but the interference was there - just slightly enough for me to punt this approach. Then I figured if I make some small cuts out of the front metal, I could their swap sides and tuck the latches inside the frunk (darkened area of blue tape to be cut out) with the latch actuator arms pointing inside:
Then I had to come up with a bolt-on plate that would be at the correct angle so that the latching shoulder bolts would be at the right angle and location to intercept the latches. I had some aluminum sheet lying around, so I started to mock this up. This will bolt into the hood at the original two locations but will span further apart and to this I will bolt the latch shoulder bolts:
The angle turned out perfect and the clearances are very good.
As they are oriented now, the latches can either be push actuated by a rod on each side or pull operated by cable or rod. The latches are hidden out of the way under the wire runs in the front. I like this approach. If my hood plate work, I might have to find someone to make a nice one for me. I have limited sheetmetal tools.
I will start cutting the front soon.
SpyderMike 09-15-2017 10:39 AM
oh, here are the latches and one of the shoulder bolts:
http://forums.pelicanparts.com/uploa...1505497118.jpg
jimtweet 09-15-2017 12:20 PM
You know they make a long hood that can bolt onto a stock short hood car and use all factory latches
SpyderMike 09-15-2017 02:04 PM
Of course, but where is the fun in that?!
Mine is an all steel backdate and I have an original hood. This solution is minimally invasive and the latches were less than $30 total. Anyone can do this...
http://forums.pelicanparts.com/porsche-911-technical-forum/819396-so-how-backdate-project-starts-9.html
SpyderMike 09-15-2017 03:43 PM
so a couple of hours later and I have the latches installed. The bottom of the slot is right where there were holes drilled by the factory for the smile or something (I don't recall). All I did was slot down to them. The brownish stuff was there from the existing hole. The holes are still rough openings and need to be cleaned up and the area painted:
http://forums.pelicanparts.com/uploa...1505514283.jpg
From inside - perfect locations. The actuators are right under cable straps so that the wiring is kept out of the way. These latches seemed to be perfect for this application.
http://forums.pelicanparts.com/uploa...1505514283.jpg.
I slotted the mount holes for the hood plate:
and installed it:
http://forums.pelicanparts.com/uploa...1505515176.jpg
Looking in from the side, you can see the clearance between the bracket and the latch:
The red shows where the shoulder bolt will pass through. I am going to source slightly smaller (in diameter) shoulder bolts than the ones it came with. The head is too big.
I will also trim the hood latch plate to remove excess material and prep for paint once I dial everything in. I am thinking I will use rods behind the horn grills (one for each side) to activate the latch releases. The movement to release is only about 5 degrees.
Uwon 09-16-2017 09:31 AM
That's allot of nice work. It's going to be interesting to see how you address the attachment of the long hood extension and required rigidity for the latches and hood flexing against the rubber.
Johan
SpyderMike 09-16-2017 10:23 AM
Not sure what you are saying. My long hood is a Porsche factory new piece. I am simply attaching it with latches near the original factory attachment points on both the early factory hood and the late factory front end. The attachment points (you know this well) are only offset about 2 inches axially along the length of the car, and I am latching about mid point between them.
Uwon 09-16-2017 12:00 PM
Oops! My mistake, was looking at your pics on my iPhone in the blazing sun at the beach Nice and tidy solution. Are you proposing to need both hands free to actuate each latch thru the grills?
Johan
SpyderMike 09-16-2017 12:34 PM
I will unlatch one at a time...the latch opening is spring loaded and moves out of the way. Might need a slight spring lid popper, I will see.
Actually, I could use the hood release feature of my remote locking system to actuate the latches simultaneously....hmmm. That would be too easy.
Uwon 09-16-2017 08:04 PM
A remote actuator would be nice, but, if you had one, you should consider a secondary safety hook latch. Imagine if you inadvertently hit the remote while driving. :(
Johan
SpyderMike 09-17-2017 10:35 AM
I hear you...I would still need a manual way for times when the battery is dead. Yesterday I prototyped a simple small bellcrank where the original latch was located. It works fine to pop both latches simultaneously. I might be able to connect it to the original hood handle wire for single point actuation.
The latches work great...the hood is down and locked with no vertical movement.
Harpo 09-17-2017 04:14 PM
As usual great work here Mike. I really want to keep the factory latch & striker. I had considered the rubber latches but I want a cleaner look. I found a photo here on pelican with a remote pull to release the secondary latch. I have a hard copy but I cant find my electronic one so I can post it.
Keep up the good work
Harpo 09-17-2017 04:19 PM
Found it
http://forums.pelicanparts.com/porsche-911-technical-forum/379658-here-we-go-again-zuffenhaus-ms-rsr-project.html
First page post 3
SpyderMike 09-17-2017 04:29 PM
I couldn't readily find a shoulder bolt meeting my needs, so I created one with a steel spacer and some hardware. It works perfectly in this application:
http://forums.pelicanparts.com/uploa...1505690345.jpg
I cleaned up the holes with a small file (I still need to paint the exposed metal):
The latches allow the hood to fully seat and the hood doesn't move at all. I have some lockwire attached to the latch release levers and coming out of the side of the frunk so I don't accidently lock the hood down with no way to release it.
Then the conversation with Uwon on this thread got me to think of a way to release both latches with one pull. I figured a simple bellcrank should work and I could use the original location of the single latch. I had some L angle aluminum laying around so I made this prototype in about 15 minutes. You can see my safety wires. It works like a charm! I think I can design this to actuate by pulling the original handle in the cockpit.
The safety wires will all be replaced with nicer covered swagged cables or with rods.
SpyderMike 09-17-2017 04:36 PM
Originally Posted by Harpo (Post 9741142)
David,
I am not sure there is clearance to pull that handle in a backdate...the front lip of my lid sits very close to the bumper top:
http://forums.pelicanparts.com/uploa...1505691167.jpg
I have some thoughts about coming out of the frunk behind the horn grills with either push rods or pull cables. I also see a couple of options to exit under the car through holes in the frunk (I got rid of the spare, the jack and the A/C system)...so reach under and pull down to release would work for me too.
dwelle 09-18-2017 03:37 PM
harpo, i did something very similar on my backdate. i used a small cable thru a contoured tube mounted under the lip. when you pop the hood, you just reach under the front lip and the pull is right there, works very well. no pics handy.
by the way, mike, i got mine all done. my car is in for final fitment and paint. really happy i went with all steel instead of FG.
i only made one cut on the car to remove the tow bracket on the driver side rear bumper. everything is bolt on and easily reversible...
SpyderMike 09-18-2017 08:15 PM
congrats dwelle! Where is your build thread? I want to see your car!
I also got some thin rod material, some "throttle cable swivels", and some hardware to finish off my bellcrank front hood latch. Pretty happy with how it works. I need to figure out a single point pull and a spring return and I am set. That will have to wait until I get my rear pumpers and panel on.
dwelle 09-18-2017 09:25 PM
ha! no build thread, i'm just trying to get this one back on the road and start driving it so i can get to the '73 RSR that's right behind it...
Uwon 09-20-2017 11:12 AM
Mike, this is how I dealt with the secondary safety latch. It's obviously a different approach. You will likely recall that I grafted the short hood latch sub-frame to an original long hood. Maybe consider a long hood secondary safety latch installed on your longhood, A pin sticking horizontally out of the slam panel, and a pull wire/handle similar to the pics below.
http://forums.pelicanparts.com/uploa...1505930953.JPG
Cheers,
Johan
