-   -   MFI hard lines- interference with throttle (http://forums.pelicanparts.com/porsche-911-technical-forum/970334-mfi-hard-lines-interference-throttle.html)
Neilk 09-15-2017 11:49 AM
Hello,
After 20+ years of carbs, and about 10 years of having MFI parts in a box, I am finally reverting my car back to MFI. I test fit the hard fuel lines and throttle rods/cables and noticed that the rod was rubbing slightly on the #3 fuel line. I managed to nudge the line in a bit to give myself 1/4" of clearance, but would like to see how the lines should align.
I searched all over, but couldn't find a good shot from the front of the engine looking back. Can some one post some from the same angle?
http://forums.pelicanparts.com/uploa...1505501334.JPG
Note: Those pictures were before I bent the line a bit to give me more clearance.
Thanks,
Neil
matthewb0051 09-15-2017 12:09 PM
Neil,
I can try to get a photo later today/tomorrow.
My .02 - the offending line looks like it is bowed. You should take it off and 'bow' it the other direction. Carefully. Looks like engine is out so now's the time.
Neilk 09-15-2017 12:44 PM
Thanks Matthew, it looks bowed to me too.
I am trying to determine how much I need to bow it in the other direction. I'll look forward to seeing your pictures.
matthewb0051 09-15-2017 03:24 PM
Sorry, the photos were a bust. Just couldn't get the phone in there. My line that goes to cylinder 3 looks like it runs at a different angle or plane that the longer 2. It's under the other 2 lines and nowhere near the throttle linkage. Your lines all look parallel, different from mine.
eimkeith 09-15-2017 04:58 PM
Matthew is right; that line is tweaked, untweak it.
Helps if you loosen and re tighten, sometimes.
Inkblot 09-15-2017 07:51 PM
Here's a pic from my recent teardown- it isn't quite the angle you're looking for, but does show that the 3 lines run parallel and in-line (lower right part of pic). Suggests that the others are correct, one of your lines may be a bit bent outta shape.
http://forums.pelicanparts.com/uploa...1505530234.jpg
-Jake
Inkblot 09-16-2017 11:11 AM
Here are a few pics of my lines, removed from the engine and cleaned up a bit. Hopefully you can see where they should/shouldn't be bending.
http://forums.pelicanparts.com/uploa...1505585421.jpg
- Jake
Neilk 09-18-2017 07:03 AM
Thanks for the pictures.
Interesting that the parts manual only shows that bracket/clamp on the right side of the pump and not the left. Guess I need to order two of them.
