MFI hard lines- interference with throttle
Hello,
After 20+ years of carbs, and about 10 years of having MFI parts in a box, I am finally reverting my car back to MFI. I test fit the hard fuel lines and throttle rods/cables and noticed that the rod was rubbing slightly on the #3 fuel line. I managed to nudge the line in a bit to give myself 1/4" of clearance, but would like to see how the lines should align.
I searched all over, but couldn't find a good shot from the front of the engine looking back. Can some one post some from the same angle?
Note: Those pictures were before I bent the line a bit to give me more clearance.
Thanks,
Neil
Neil
'73 911S targa
Old 09-15-2017, 11:49 AM
Neil,
I can try to get a photo later today/tomorrow.
My .02 - the offending line looks like it is bowed. You should take it off and 'bow' it the other direction. Carefully. Looks like engine is out so now's the time.
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 09-15-2017, 12:09 PM
Thanks Matthew, it looks bowed to me too.
I am trying to determine how much I need to bow it in the other direction. I'll look forward to seeing your pictures.
Neil
'73 911S targa
Old 09-15-2017, 12:44 PM
Sorry, the photos were a bust. Just couldn't get the phone in there. My line that goes to cylinder 3 looks like it runs at a different angle or plane that the longer 2. It's under the other 2 lines and nowhere near the throttle linkage. Your lines all look parallel, different from mine.
Old 09-15-2017, 03:24 PM
newb.
eimkeith's Avatar
Matthew is right; that line is tweaked, untweak it.
Helps if you loosen and re tighten, sometimes.
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 09-15-2017, 04:58 PM
Inkblot's Avatar
Here's a pic from my recent teardown- it isn't quite the angle you're looking for, but does show that the 3 lines run parallel and in-line (lower right part of pic). Suggests that the others are correct, one of your lines may be a bit bent outta shape.
-Jake
'75 911S 3.2
'73 911 T MFI Coupe Silver Metallic (in progress...)
Sometimes nothin' can be a real cool hand...
Old 09-15-2017, 07:51 PM
Inkblot's Avatar
Here are a few pics of my lines, removed from the engine and cleaned up a bit. Hopefully you can see where they should/shouldn't be bending.
- Jake
'75 911S 3.2
Old 09-16-2017, 11:11 AM
Thanks for the pictures.
Interesting that the parts manual only shows that bracket/clamp on the right side of the pump and not the left. Guess I need to order two of them.
Neil
'73 911S targa
Old 09-18-2017, 07:03 AM
