TigerTrash's Avatar
bad things happen when outta gas
OK need any help I can get.
Was out to fuel the german mistress tonight. I went and pulled on the fuel door release cable and ended up with about 18 inches of cable and a knob in my hand. ( And I didn't even yank that hard). So here is the question. How do I open the door to the fuel tank (as there is only about 1/10th of a tank left). and how do I replace the cable. In advance, my fellow pelicanites, all help is greatly appreciated.
83 911SC Coupe
SCWDP-Member
Old 06-09-2002, 08:29 PM
Senior Member
A pair of hemostats (those surgical instruments that "some people" used when smoking homemade things when eons younger) or a small screwdriver can be used to push the latch holding the door.
You should find the old cable stop either still resting in the cradle or sitting on the bottom of the fueling bay. Since you cannot see what you are doing, here is a picture of what to look for.
Looking at the latch from top
Looking at the latch from the left side
You should be able to see how with something small and thin you can get into the area and move the latch to where you can get the door open again and re-attach the cable. You might also try an icepick from the back side of the door. I would also put some duct or masking tape around the edge to protect the paint before trying to get this open.
Joe
Old 06-09-2002, 08:51 PM
pwd72s's Avatar
Thanks Joe, for the pics. I just gave a long answer to the same post on Rennlist, trying to describe what was under the flap...suggested he make a J shaped tool to slide through the loop of the latch, then pull forward.
Old 06-09-2002, 10:24 PM
I read somewhere--probably here--that one should carry about 18 inches of mono cord or trimmer cord to slide under the fuel door and pull towards the front of the car. Haven't had to try it yet but the cord is in my tool kit!
george 86Targa "Jessie"
Eternity is long, especially near the end!
Old 06-10-2002, 12:00 AM
911 user
Milu's Avatar
There might be less risk of damaging your paint if you use a piece of plastic strimmer wire or fishing line. Just insert, from bottom edge, push through and then pull from both sides. (every toolkit should have one next to the DME relay)
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 06-10-2002, 12:01 AM
pwd72s's Avatar
Plastic trimmer cord? Sure it would work! Simple & brilliant! Probably why I didn't think of it...
Old 06-10-2002, 08:35 AM
TigerTrash's Avatar
my thanks to all who replied. It sounds like the best way is the trimmer string idea. I will post the results when I get home tonight and try it.
NOW, does any one know how to replace the cable if in fact I can get the door open.
83 911SC Coupe
SCWDP-Member
Old 06-10-2002, 08:37 AM
pwd72s's Avatar
That should explain itself to you once you get the flap open...the opener cable is held by a simple set-screw arrangement...
Old 06-10-2002, 08:49 AM
TigerTrash's Avatar
My thanks again for everyone's help. I had to stop by the house during lunch today and after ten minutes of rooting through boxes(we just moved) to find the trimmer cord I cut about a 18" piece and tried to open the gas flap. WOW under 5 seconds to get it open.
Bad News:The cable snapped about a 1/2 inch from the set screw and can't be reused.
Good News: a new one is $7.95. I can't remember the last time I spent under $100.00 to fix something on the car.
FYI: everyone should keep a piece of this in their toolkit. I know I will from now on.
I will post pics of the new garage when I getta chance. 4 car garage with drains. lots of industrial shelving. SUPER bright. WOOHOO.
83 911SC Coupe
SCWDP-Member
Old 06-10-2002, 10:44 AM
Saffs's Avatar
Easier still, go to a music shop and buy a top E string for an electric guitar. Or, you could get a top E string for a "classical" guitar in nylon - but might need to buy a set for that. I've used guiar strings for all sorts of car applications fron tying exhausts up to filler flap opening.
'81 BMW Alpina C1 2.3
Just sold, '75 911S Targa
Old 06-10-2002, 11:08 AM
Senior Member
Doug Zielke's Avatar
Ahhh, thank you Paul. I posted that little tip a few months ago, and it really does work, and won't hurt the paint.
And here's another little tip.....try doing it *before* your cable breaks. That way you'll remember the *feel* it takes to do it.
And be sure to keep a piece of trimmer line (0.065") in the glove box.
(See Paul, we guys from the SCWDP aren't that bad after all. )
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 06-10-2002, 05:42 PM
bdisco's Avatar
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
Got the new cable. Cable seems to be getting stuck with 3" to go. After taking out the cotter pin to see what was holding it up (HUGE MISTAKE). Three hours later we reinstalled the spring and cotter pin and cable still won't go through. Your help is greatly appreciated.
'88 Carrera
Old 04-17-2009, 02:19 AM
T77911S's Avatar
german mistress, i like that one
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-17-2009, 04:27 AM
Wer bremst verliert
JohnJL's Avatar
We've all got at least one.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-17-2009, 04:35 AM
Trimmer cord, guitar wire...good lord, I have a simple piece of nylon string in the glovebox with finger-loops tied into each end that I use. It's simpler than using, say, a length of neural fiber from an unborn ocelot, or perhaps a length of string-theory equation. Simplicate, people, simplicate.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-17-2009, 04:40 AM
bdisco's Avatar
Got the new cable. Cable seems to be getting stuck with 3" to go. After taking out the cotter pin to see what was holding it up (HUGE MISTAKE)*. Three hours later we reinstalled the spring and cotter pin and cable still won't go through. Your help is greatly appreciated.
So any ideas what prevents the cable from going all the way through? Hard to look cool when you pull up to the pumps and have to use a shoe lace to open your gas flap.
*Fuel door lock - sticky cable fix
'88 Carrera
Old 04-17-2009, 07:09 AM
I've used dental floss.
Old 04-17-2009, 09:02 AM
the plastic zig zag tube makes it hard to get the cable through. bend a slight angle in the leading end and keep twisting as you push. you ain't the only one.
206 637 4071
Old 04-17-2009, 09:19 AM
Dental Floss is a good thing to keep in the car.
Ever been out to dinner and got something stuck in your teeth and you can't get it out.. Really sucks.
With this gas cap door thing a roll of it should be in with the spare relays and other gadgets some people stash in the car somewhwere.
Old 04-17-2009, 09:37 AM
richard003@wind's Avatar
Follow Johns advise, That is what worked for me.
1979 911 SC... 83 911 SC .... 82 911 sc.... Fiat 124 Spider Full Race
Old 04-17-2009, 09:40 AM
