Cosmoline remover?
Currently working on changing shocks all around. Working on the front and was looking for a cleaner to remove the cosmoline on the struts. Used a degreaser it helped but took a long time. Looking for something easier
Old 02-27-2017, 07:37 PM
Gasoline
Old 02-27-2017, 08:16 PM
ROW '78 911 Targa
timmy2's Avatar
diesel
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-27-2017, 10:13 PM
Diss Member
Quicksilver's Avatar
You can use gasoline but kerosene or diesel won't go 'WOOMP' on you from a static spark. After that a degreaser will get the last hint off if you want it 100% clean.
I shouldn't have to say it but chemical gloves are fairly important. I used to do a lot of transmission mods and suddenly after a few years, one day I came up with a sensitivity to solvents. (Hives covering every exposed bit of skin!)
The sensitivity went away after a decade but I see no reason to repeat that "learning experience".
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-27-2017, 11:01 PM
DanielDudley's Avatar
Steam.
Old 02-28-2017, 02:17 AM
Alexm930's Avatar
We used Kerosene back when I worked at the Dealer.
Speedlimits are for the guidance of wise-men & the obedience of FOOLS!
Old 02-28-2017, 06:49 AM
Almost Banned Once
sc_rufctr's Avatar
I've used mineral turpentine with good effect. Not cheap and you need lots of rags.
Try soaking it to soften it with a soaked rag. Then scrap off as much as you can without damaging the paint underneath. (flat wooden stick)
Then use rags and turps on the rest. Soap and a pressure wash to finish it off.
- Peter
Old 02-28-2017, 07:24 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Get a gallon of final wipe or pre-clean from the local paint jobber. It flashes off faster than turpentine and you can use it as a bug and tar remover on your paint without issue. Not too much lingering smell.
All the others mentioned will work fine.
1981 911SC Targa
Old 02-28-2017, 10:05 AM
Chlorinated brake cleaner
spray a little on a rag and rub like a genie bottle. If you are in an enclosed space you might even see a genie
BEFORE
AFTER
Yes I left the caliper. Rather leave it protected by cosmoline since it's black anyway.
Old 02-28-2017, 11:40 AM
Thanks for all the info guys. Gas is working great.
Old 02-28-2017, 04:31 PM
any suggestions for cosmoline removal on painted body panels?
Old 09-26-2017, 02:25 PM
'73 911 T Targa
I think Naphtha should do it. Naphtha should not hurt a fully cured finish. I use it to wet sand woodworking finishes. It evaporates quickly and doesn't leave behind any residue.
Old 09-26-2017, 04:41 PM
wayne robson's Avatar
cleaning
Like Bob says , all painters use a degrea.ser , prepsol
it is safe on any car surface, will not hurt your paint finish
all paint shops sell it , i have a small pint tin in my garage all the time,
thick oil can first be removed with brake clean then finish with prepsol ,
but not on paint finish..
Old 09-26-2017, 04:54 PM
