need help identifying these 3 wires...
While taking apart everything to drop my motor, I noticed the 3 wires in the pics below seem to have been cut... no idea what they are.
Can someone help identify what these go to? This was obviously done by a PO. ![]()
1987 Porsche 911 Carrera Coupe |
Hi..the wires look like for a 3rd brake light ...
Ivan |
No... because I have the original 3rd brake light, and it works fine.
![]() Just an FYI... the wires are wrapped in the same gray loom as the wires that go to the ignition coil.
trakrat..again, the black yellow is for brakes ,brown ground and the white goes to you licence plate light. Somebody cut it off....all the wires are wrapped originally to gray ....
Ivan |
