How to get this brake line off the trailing arm - special tool?
See this pic - because of the recess, I can't get enough of the wrench to grab the nut, which I have to counter hold to loosen the brake line. I've looked for a special tool to do this, but can't find one. What do you guys do? With the notorious stripping of nuts on brake lines, I am reluctant to half-ass it. This is the only thing keeping me from removing the training arm.
http://forums.pelicanparts.com/uploa...1506990293.JPG |
looks like an O2 sensor socket would work not sure the size though
Take a picture of the other side of the fitting. May be just a clip holding it in there.
I see 4 options
If it's just held in place by the clip, remove the clip and push through otherwise: cut a slot in a box end wrench that will go over the line. should fit in the recess but if it doesn't, you could grind the perimeter Cut the brake line and use a deep socket, replace line Cut the hard line and pull it through, replace hard line |
I feel like an ass, yes there is a clip. I'll try tonight. http://forums.pelicanparts.com/uploa...1506994186.JPG
At least you are honest, and now I know there is a clip there. I plan to change mine sometime this winter. Thanks for the tip and photo.
86 Carrara. |
Whoever installed that clip, did it wrong side out. It should be installed with the lip facing out so you can get a hold of it for removal. Also the curvature if the main part of the clip should act as a spring to help pull the hose mount into the bracket.
Like he said ^ The brake clip is flipped,
but using the following method you should be able to carefully work it out. I wasn't able to pull mine from the top even with it facing the right way. Use a bit of pressure on each side to work the clip carefully up and protect the arm with a wood block so you don't scratch it up. http://forums.pelicanparts.com/uploa...1507038596.jpg |
pry the clip off.......use "line wrenches" to loosen fittings.
URL="http://http://www.sears.com/craftsman-9-pc-standard-and-metric-flare-nut/p-00944096000P#"]http://http://www.sears.com/craftsman-9-pc-standard-and-metric-flare-nut/p-00944096000P#[/URL] |
worst case, you could put some vice grips on the barrel end that the tube nut is threaded into. Its the same part as the hex you can't get a wrench on so if you can hold it with the vice grips and then use a line wrench to loosen the tube nut you'll be in business.
| All times are GMT -8. The time now is 12:36 PM. |
