-   -   need help! Can't drop engine because of this... (http://forums.pelicanparts.com/porsche-911-technical-forum/972876-need-help-cant-drop-engine-because.html)
Trakrat 10-06-2017 02:12 PM
I have an unknown wire that I'm not sure how to remove. It looks like this goes to the passenger side fuel injectors...
Can someone tell me how to disconnect it???
Thanks!
http://forums.pelicanparts.com/uploa...1507324369.jpg
proporsche 10-06-2017 02:17 PM
Hi Just unplug it ..You are missing the top cover so make sure you do not mix up the wires..it is part of the engine harness
Ivan
pmax 10-06-2017 02:17 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/911566-911sc-electrical-plug-back-engine-compartment-driver-side.html
cabmandone 10-06-2017 02:41 PM
The base slid out of the holder. Grab the top with one hand and the bottom with the other and pull them apart. It should be 6 or 8 pins, I don't recall exactly so don't hold me to it.
HEY! Put the top cap back on that thing before the wires pop out too! After looking at the pic and seeing your wires.. it's a 4 pin :-)
juanbenae 10-06-2017 02:44 PM
take a better picture 1st cause when you unplug those the wire spuds will likely dislodge. you'll be glad you did. every time I thinned out a 14 pin for my racecar build and thinning of my current hotrod project I was always nervous as fuch because a picture does little good on those.
