need help! Can't drop engine because of this...
I have an unknown wire that I'm not sure how to remove. It looks like this goes to the passenger side fuel injectors...
Can someone tell me how to disconnect it??? Thanks!
1987 Porsche 911 Carrera Coupe |
Hi Just unplug it ..You are missing the top cover so make sure you do not mix up the wires..it is part of the engine harness
Ivan |
Still here
Brew Master
The base slid out of the holder. Grab the top with one hand and the bottom with the other and pull them apart. It should be 6 or 8 pins, I don't recall exactly so don't hold me to it.
HEY! Put the top cap back on that thing before the wires pop out too! After looking at the pic and seeing your wires.. it's a 4 pin :-) Last edited by cabmandone; 10-06-2017 at 02:43 PM.. |
Disbanded
take a better picture 1st cause when you unplug those the wire spuds will likely dislodge. you'll be glad you did. every time I thinned out a 14 pin for my racecar build and thinning of my current hotrod project I was always nervous as fuch because a picture does little good on those.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
