Rear sway bar bushing
I'm having hard time inserting this new bushing into the opening.
Any trick to it?
Thank uou
Old 10-07-2017, 07:02 AM
ninelevenick's Avatar
What year is your 911? Anyway, you should be able to pinch or squeeze the bushing while jamming it into the drop link. That's why there is a slit designed in the bushing. Also, you can lube the inside of the drop link with dish soap.
Old 10-07-2017, 07:15 AM
The slit allows you to roll the top into the bushing hole to then fit into the mount; once it's through it expands back with the lips on the outside of the mount.
Rutager West
Old 10-07-2017, 07:23 AM
cycling has-been
bkreigsr's Avatar
I used a bench vise, plastic putty knife and a bunch of dish soap.
I though that if I rolled it in, there would be a chance I would rip it.
Bill K
Old 10-07-2017, 07:46 AM
Done thank you
Old 10-07-2017, 08:19 AM
