-   -   How do I install these? (http://forums.pelicanparts.com/porsche-911-technical-forum/973072-how-do-i-install-these.html)
93097004xx 10-07-2017 06:15 PM
I’m asking how do I remove the old ones without breaking the levers they are attached to?
https://uploads.tapatalk-cdn.com/201...b18aac0b79.jpg
rwest 10-07-2017 06:19 PM
They just pull off- friction fit; don't bend side to side.
93097004xx 10-08-2017 03:51 PM
Tried this but they are on tight worry about breaking the levers.
sugarwood 10-09-2017 07:06 AM
Heat gun gentle?
aread 10-09-2017 07:09 AM
Originally Posted by sugarwood (Post 9769015)
Heat gun gentle?
Yup, heat gun worked them loose for me. Low, low heat.
Flojo 10-09-2017 07:16 AM
Heat gun gentle?
NO!
heats up way to fast and hot! even gentle.
use a hair drier and then some wood to hammer off from backside gently.
tcar 10-09-2017 09:42 AM
Put a pair of vise grips on the backside, snug but not tight.
Gently tap the grips with a small hammer.
Did not need heat.
93097004xx 10-13-2017 09:46 AM
Go it off! Taped it off a few times to keep from damaging it the pulled off with pliers.
Then found this..
It was installed upside down.. it has faded just on the side it was installed.
So debating on whether to install the new one or try to refurbish the original.
https://uploads.tapatalk-cdn.com/201...161f6cc0b4.jpg
https://uploads.tapatalk-cdn.com/201...dc36f0e0f0.jpg
tcar 10-13-2017 10:16 AM
Refurbish is easy.
Pan of hot RIT red dye for a couple hours.
Use white-out in the recesses, it's latex paint. wipe off the excess.
