How do I install these?
I’m asking how do I remove the old ones without breaking the levers they are attached to?
http://9309700485earlyturbo.wordpress.com
Old 10-07-2017, 06:15 PM
They just pull off- friction fit; don't bend side to side.
Rutager West
Old 10-07-2017, 06:19 PM
Tried this but they are on tight worry about breaking the levers.
Old 10-08-2017, 03:51 PM
sugarwood's Avatar
Heat gun gentle?
1986 Bosch Icon Wipers coupe.
Old 10-09-2017, 07:06 AM
Jacksonville, Fl
Originally Posted by sugarwood View Post
Heat gun gentle?
Yup, heat gun worked them loose for me. Low, low heat.
Alex
Jacksonville, Fl
'88 Carrera, Guards Red
Old 10-09-2017, 07:09 AM
Flojo's Avatar
Heat gun gentle?
NO!
heats up way to fast and hot! even gentle.
use a hair drier and then some wood to hammer off from backside gently.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-09-2017, 07:16 AM
Put a pair of vise grips on the backside, snug but not tight.
Gently tap the grips with a small hammer.
Did not need heat.
Old 10-09-2017, 09:42 AM
Go it off! Taped it off a few times to keep from damaging it the pulled off with pliers.
Then found this..
It was installed upside down.. it has faded just on the side it was installed.
So debating on whether to install the new one or try to refurbish the original.
Old 10-13-2017, 09:46 AM
Refurbish is easy.
Pan of hot RIT red dye for a couple hours.
Use white-out in the recesses, it's latex paint. wipe off the excess.
Old 10-13-2017, 10:16 AM
