Erratic Warm Idle Finally Solved
I have been chasing a rough warm idle dragon for literally years. I worked around it through various methods but I never had a smooth running car, even after a complete rebuild.
I have fixed or checked every possible vacuum leak. I have replaced the fuel injectors. I have replaced fuel filters. I have check fuel pressures. I have replaced wires and plugs and had the distributor rebuilt. I have checked WUR, AAR, AAV. I have checked the O2 Sensor Relay. I have pulled and check the air box for separation I have fine tuned the mixture at idle... perfect at warm up and warm, the rough idle could not be corrected. I have even resorted to checking the cupboard for more 12 year old Scotch to give me the strength to keep at it. Well... I finally found the issue and I wanted to share it because I am sure I am not the only one with the issue. I replaced the CAT in preparation for an upcoming smog test and decided to replace the Oxygen sensor at the same time. The new Bosch unit did not have a connector, so I snipped off the old connector to attach a new bullet connector and there it was... there was the issue, such a simple thing and I never thought about it being an issue.... wait for it... My 1980sc uses a Coax for the oxygen sensor lead from the ECU. Outside is grounded shielding, inside is the positive lead. Some jacka$$ long before I bought the car stripped the wire of the coax and put on a new connector using both wires of the coax.. shorting out the two wires. The Oxygen sensor never could send a signal to the ECU. After sobbing like a little girl (other CIS owners can appreciate)... I carefully separated the coax wires and clamped on a new connector. Vvvvrrooooommm! Well.. the car is so smooth and quiet now, I thought I stalled it this morning because I didn't hear or feel the engine with the radio on. Now with all my free time I may start listing all the parts I have replaced on ebay! |
Fleabit peanut monkey
Just talking. I think the O2 sensor sent a signal but it was off the scale (one way or the other - rich vs lean) causing the Lambda box to try to correct a totally bogus signal. Now you have the opportunity to dial it in. Just for discussion, I think the 1980 box is morphed from 944 box. In 81 it got a 911 number. There may be an upgrade from 81 to 83, maybe? It's not an ECU engine management box but it's the best CIS had in the later SC's.
1981 911SC Targa Last edited by Bob Kontak; 10-09-2017 at 03:58 PM.. |
| Tags |
| o2 sensor , oxygen sensor , rough idle , rough warm idle |
