avi8torny's Avatar
Send a message via AIM to avi8torny
Bilstein Insert w/Boge struts revisited
I have looked at a few threads relating to this and do not see a definitive answer to the parts that come with these struts.
Does the small rubber washer that comes with the new insert remain on the shaft, essentially sandwiched between the dust cover and the sealed cartridge? It would seem that this would keep the dust cover from vibrating on the shaft when the upper perch is tightened up.
Anyone have some insight to this?
12' GT3
18’ 991S
Old 02-07-2003, 08:05 PM
rdane's Avatar
Bilstein says throw them away, which is a good thing since I had already left the little buggers off which promptedthe phone call
When you bolt them down there won't be any vibration or rattle without them, so no worries.
Old 02-07-2003, 08:27 PM
