Cars and Cappuccino
Very cool pics. But what's with the naked, one-legged invisible man hanging out in his white boot?
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
SWB 2.2 lightweight. Runs and drives but can always be improved. |
Some really good information / pictures. Thanks all. Sent an email to seller to find some more information. Looking to see if anyone is willing to fab up something similar; maybe under a group buy.
I'll never understand the people on here that come right out and poo poo anything that isn't original from the factory. Honestly, how bad could this piece be? Some of you make it sound like these cars are so temperamental that the slightest mod will rain fire and brimstone from above. I think it's safe to say these air cooled cars can take a little modification here and there and still survive. I mean they're still on the road now, 50+ years later, and we all know that most had previous owners that may not have been the most maintenance conscious. OP - if you like this piece and you can find one, or have one made, put it on your car if for the only reason is it looks bad ass ![]()
1983 SC - sold 2002 996 C4S - sold 1968 912 |
3 restos WIP = psycho
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Functionista
![]() Millions of bugs south of the border can’t be wrong...
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
+1 .... ??? What are those wheels, LIKE!
76' 911s Signature Edition |
Jon Bingham
Grill air scoop
If that scoop didn't work then why Porsche's Turbo Exclusive and Techart using them ?
The roof angle is much different on the new 911's.
You would need a wind tunnel to test the difference between the ram air effect and the low pressure area formed by the windshield slope. The grill is designed to let heat run upwards and out, and a low pressure area behind the windshield would help this at speed. Forcing air into it might work better at certain speeds, but it does look cool. As for the bug, they didn't convert their factory grille, they opened up another hole to allow heat to escape. That's a big difference. |
I really like this design and it seems to this lay person's eyes to be the most functional of all the designs in this thread. Here we have retained the original grille and added a scoop to the lower portion of the decklid for enhanced cooling.
If I were doing this mod today, I would choose this design. |
GunterWerks
Another scoop by Gunterwerks
The wheels look like what Farrari used in the 70s
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
Would this benefit an intercooled turbo?
Would a scoop like this, benefit a turbo with an intercooler? I've run my car with no decklid and the intake temps are quite stable and "low". With the spoiler added, I found that hot air had no way to escape and once heat soaked the intecooler, it was quite difficult to get the temps to lower again. Curious if anyone with a turbo has used a scoop like this? I'm guessing if it was effective, plenty would be doing it...
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Those are JAP (J.A.Pearce Engineering) "Magna" wheels
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD 1976 914 2.0 Lime Green Metallic - Completely stock |
It's a 914 ...
Thanks to Tom for answering the 7 year old question about the wheels!
The black 911 in pictured just above sure is pretty. As for the scoop, I'd have questions. Not saying it doesn't work, but the grill area on a 911 is a lower pressure area, not the ideal place for a low scoop like that. And the "open area" of that scoop is substantially less than the plan area it feeds. The engine fan does a lot of the work to bring in air through the decklid grill, so a scoop like that may have limited benefit on an early 911. |
Decklid scoop
Similar concept. Perfect Power in Buffalo Grove, IL.
Full Send Society
Decklid Air Scoop - Help Identify & Source
Given that the various engine fans pull between 1300-1500 l/sec (~2700-3100 cfm) which is a ton of air (a 20’x20’x8’ 2-car garage), it seems suspect that a small scoop that obscures most of the fan’s access to air would significantly increase the cfm.
https://forums.pelicanparts.com/porsche-911-technical-forum/332048-5-blade-fan-vs-11-blade-fan-3.html It’s cool looking in a very 1960s lack of data type way but effective…? RUF did have a scoop on some cars but iirc that was to aide in cooling the internet, not the engine. Again, not sure how effective. Singer puts naca ducts on the quarter windows and sends that air to the engine… not sure if that’s for show or backed up with data… I think one of the conclusions from Frere’s 911 book was that the fan does amazing and that a ducktail (or similarly shaped scoop) won’t increase the amount of air entering the engine bay but it might take some (tiny amount?) of the load off the fan… but this was all at race speeds where everything is a bit different that tooling around town… Now, do grille scoops limit the amount of dust and exhaust that gets pulled into the engine bay from the rear of the car… maybe, and that’s something to consider if you’ve ever taken your car into gravel or dry dirt roads!
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html Last edited by Showdown; 01-05-2025 at 05:19 AM.. |
