88 Carrera, Guards Red
azhodge's Avatar
Relay Post Cleaning
Noticed my horn was not working or working intermittently. Traced the problem to corrosion on the relay posts. This tells me that I need to clean all the relay posts and sockets. I can pull each relay and use a piece of emery cloth to clean the posts up. I was wondering what people have used to get down into each posts socket? I have DeoxIT to clean and treat the connections but I would still like to get down into the socket. easy over hard would be appreciated...
Old 10-14-2017, 01:29 PM
BER BER is offline
BER's Avatar
I have used a trimmed Q-Tip and Deoxit corrosion cleaner. Works well, unless the the metal is actually pitted.
If you have a guns & ammo store nearby (Bass Pro, Cabelas, etc), they make several types of cleaning tools that will fit into small diameter sockets.
Bruce
'12 Carrera S DFI
'84 911 Carrera
Old 10-15-2017, 05:53 AM
Been here a while
I also run a razor blade between the tabs on the relay itself, spread them out just a touch so they fit tighter into the socket. I had a fuel pump relay fall out at an autocross once....
looking for 1972 911t motor XR584, S/N 6121622
Old 10-15-2017, 06:32 AM
Under the radar
Trackrash's Avatar
A small piece of 220 sand paper tightly rolled will work as well.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-15-2017, 08:24 AM
azhodge's Avatar
good ideas, thanks, I also found these at harbor freight for $2
Old 10-15-2017, 05:32 PM
ROW '78 911 Targa
timmy2's Avatar
Don't go too abrasive, they are silver plated copper.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-15-2017, 07:53 PM
Vintage Owner
Jack Stands's Avatar
A bit of dielectric grease is good Insurance once it’s cleaned.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 10-16-2017, 03:31 PM
