Tachometer wiring issue
I was hoping someone might be able to guide me in the right direction on a tach wiring issue. The car is an 86 930 with recent MSD install.
Here are the steps I've taken so far:
1. Verified continuity on the black/purple wire between the 6-pin CDI plug and the engine connector plug.
2. Verified an open between the engine connector and the black/purple wire at the back of the tach.
3. Verified if I hook the MSD tack output directly to the tach with a jumper wire it operates properly.
Is there another connector between the engine connector and the tachometer that could be disconnected? Or is it just a broken wire in the main harness? I'm not sure how to even access the main harness to run a new wire, but it seems odd to me that it'd be necessary.
Any help or ideas sure would be appreciated.
Thanks,
Chris
Old 10-18-2017, 02:30 PM
ROW '78 911 Targa
timmy2's Avatar
Check continuity from 6 pin all the way to back of tach.
Could be a loose pin or socket in the 14 pin connector. Bad solder joint or a broken wire.
Check continuity from male 14 pin to back of tach.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-18-2017, 03:13 PM
Thanks for the reply.
The 6- pin to the back of the tach is open.
The 14-pin to the pack of the tach is open also, when testing with my meter.
The 6-pin to the 14-pin has continuity.
So, somewhere between the 14-pin and back of the tach is where my issue seems to be. I was curious if there is another connector the black/purple passes through that I might check? I didn't see anything behind the gauges, but it's hard to see anything back there.
Thanks again,
Chris
Old 10-18-2017, 03:46 PM
