If you search for LED tail lights by a user named Spoke, there is a detailed discussion of this situation. He incorporates a resistor into his LED brake lights to address this problem. An add-on resistor will also solve the problem, and he sells one. Or you can just go back to regular tungsten filament bulbs for the two rear brake lights.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 10-20-2017, 09:06 AM
Eng-o-neer
Tremelune's Avatar
I would think adding a resistor defeats the purpose of LED bulbs (a lower draw on the charging system). I guess it matters how much resistance you need to add...
Here's the Spoke custom LED panel thread: LED Brake Lights
Old 10-20-2017, 09:25 AM
Originally Posted by nickd View Post
I’m not sure what year you have, but the cruise control completes a ground through the brake lights and disengages when it gets +12v from that wire. With all incandescent bulbs, the resistance to ground is 6 ohms. With led/smd bulbs, it's not.
Same thing I was going to say
Old 10-21-2017, 08:32 PM
