Fuel System Tester
I am in the process of purchasing a fuel system pressure tester and want to make sure I get the right tool.
I have an '85 Carrera, so it has the DME- Motronic fuel injection system. (When I look in my parts catalogue, which is for an '86, it lists parts for an L-Jetronic I, II, and III system, and a K-Jetronic I,II, and III system. From simply looking at the pictures, it looks like a have the L-Jetronic. Is there a more definitive way to determine if I have an L or K system?) This is not a CIS system, correct? If correct, then I do not need the pressure tester that has a "T" with a shut off valve and 2 separate hoses with connectors branching out from the "T", correct? I simply need a gauge with a bleeder and a single hose with a 12 mm X 1.5 pitch connector (without a shut off valve). Interestingly, on page 240-2 of the Fuel Injection section in the Bentley Manual (for a 1984-1989) under special tools, it shows a fuel pressure gauge with the "T" and the 2 hoses. Later on in that section on page 240-7, it shows a gauge with a single hose (I think) hooked up to the connection at the end of the rail. On page 240-6 in the narrative on checking fuel pressure, it only says to connect the gauge to the fuel rail (singular). Thanks.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold |
For normally aspirated (not a 930 turbo) engine staring 1984, yes, not a CIS system.
Pressure testing is done a the LH fuel rail over cylinder 1. There is a hex head cap on a short port on the rail. Remove the cap (carefully) and there is a round steel ball which together with the cap provides seal. ![]() For testing Pressure (discussed in the shop manual sections 240 and 201), use a gauge attached to a hose, the hose fitting mating up with the fuel rail port.
Kuehl 1987 911 cab, modified https://griffiths.com/ |
Kuehl: Thank you for your reply.
Do you know how I can tell if I have an L-Jetronic or a K-Jetronic system? Thanks again.
Fuel injection classification.........
'84~'89 Carrera 3.2 engines use the air flow meter system (L-Jetronic) commonly known as Motronic system. While '73.5~'83 engines use the continuous injection system (K-Jetronic) commonly known as CIS. Going back to your inquiry about the fuel pressure gauge illustrated in the Bentley Manual, the book shows a typical fuel injection gauge kit with a shut-off valve and a pressure bleeder. Which we commonly referred as CIS pressure gauge in this form. This is actually a fuel injection pressure tester with metric fittings (12-mm X 1.5 pitch thread). Take a closer look at the above pictures. I was using the typical fuel injection pressure gauge to measure the fuel pressure produced by the fuel regulator at the fuel rail. The shut-off valve must be CLOSED when you use this pressure tester in a Carrera 3.2 or Motronic (L-Jetronic). This is the same fuel injection pressure gauge illustrated in the Bentley Manual. More versatile than a single hose pressure gauge. Tony Last edited by boyt911sc; 10-20-2017 at 09:31 AM.. |
Tony: Thanks for the clarification. That's what I was looking for.
I have found what looks like a good, 100 psi fuel pressure tester, but has fittings for GM and Ford. The tester is $32.95 and make by OTC. The only item I need is a 7/16 in. X 20 to a M12 X 1.5 adapter. Thanks.
