IAN IAN is offline
How Many Miles does a 915 Transmission Usually Last?
I have a 72 911T 2.4 MFI.
There are 137k on the entire car. The engine had a top end re-build at 100k. So there are 37 on the rebuild.
When do transmissions start to get bad?? Everything works well now, just curious.
thanks,
ian
Old 02-15-2003, 06:34 PM
s_wilwerding's Avatar
It all depends on who's been using them. If you have someone who always carefully shifts and makes sure to always fully depress the clutch pedal, the transmission might last 200K miles. On the other hand, if you have someone who likes to race off the line and often misses the shift into second, the transmission can go out in 50K miles. On average, though, I would say that most 915 transmissions start to get worn around 100K. Mine's got about 150K miles on it, and it could definitely use a rebuild - the synchros, especially 1 & 2, are nearly gone.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 02-15-2003, 07:20 PM
Colby's Avatar
Send a message via AIM to Colby Send a message via Yahoo to Colby
255k on my '84 915, and still works flawlessly!
Original motor still also...gotta love Porsche quality!
Colby
Old 02-15-2003, 08:54 PM
jwetering's Avatar
I got a 160,000 miles out of my 915. Supposedly it was apart once at 100,000 miles, and put back together without replacing any parts (drunk PO) finally I ended up shearing the teeth off of the dog gears for first. Otherwise the trans was pretty good.
jasper
jasper
2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car.
past: another 2002 996 and a 1978 SC with-webers-cams-etc.
Old 02-15-2003, 09:44 PM
Hopelessly Addicted
Porschephanatic's Avatar
My car had 4 POs and my 915 lasted 120k, so it must have seen minimal abuse.
Old 02-16-2003, 06:38 AM
zotman72's Avatar
Well I have this sweet 72 911T that was a Seattle garage queen for 13 years before I got it ten years ago. It had 87K on the clock before my torture began. I got into DEs in '98. Downshifts at speed took its toll. At 120K I replaced all the dogteeth and syncro rings, and one roller bearing that disintegrated ($$) when we opened the tranny up. I had the second to third grunch sound which was the catalyst to do the job. My rebuild experience was quite insightful but repeated woes with the input shaft seal kind of tainted things. Parts were about $900. I have used SWEPCO in the past, but now I got Redline synthetic in there. HTH.
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 02-16-2003, 07:34 AM
Just out of curiosity, what do you guys think the 915's are worth? I'm thinking about selling mine. It's from my 912e so it's never had a lot of horsepower pumped through it. It has new syncros in the last 15k or so and shift beautifully-never grinds. Thoughts?
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 02-16-2003, 07:48 AM
I know there is a company that advertises in Pano that sells 915s for around $1500. If yours is absolutely new, you may be able to get a little more, but I'd say that's about the price you'd be looking at.
Steve Wilwerding
Old 02-16-2003, 09:27 AM
thanks!
Old 02-16-2003, 09:42 AM
Free minder
Aurel's Avatar
My 915 has 104K miles on it, and needs at least new 1st and 2nd syncro rings. The differential is noisy too...I will get a quote from my mechanic to fix that, while the engine will be deposed for new exhaust head-studs, new rings, valve job and pressure-fed tensioners... If his quote exceeds $1300 for just the transmision work, I will tell him to swap it for a rebuilt one from Vertex, this is what a rebuilt 915 costs.
BTW, I have a question: my clutch has only 5K miles on it. I`d like to keep it. Is it part of a rebuilt transmission or not ?
Aurel
78 SC Targa
Old 02-16-2003, 10:16 AM
Free minder
Aurel's Avatar
I went to the Vertex website.
here
It looks like you get a clutch with the transmission. If this is the case, then it is a no brainer: Just replacing my clutch has cost me $1600 (parts+labor), while I could have had a full rebuilt transmision for $1300, and just had the labor cost to install it...Geeesh, I feel bad...
And wile the engine was deposed for the clutch job, I should have had the head-studs done too...I wish I knew all I know now at that time...
Aurel
Old 02-16-2003, 10:48 AM
I have been reading Peter Zimmermann's "The Used 911 Story",(thanks to our hosts). Peter says that 100,000 miles is the expected life of 915 tranny. Obviously, this is an estimate, and actual results may be more or less, depending on usage. (Highway versus city miles; driver habits; number of DE days, etc.)
To verify Peter's estimate, I phoned the local dealership, and they confirmed the estimate, saying that the synchros are made of molybedium (sp??). Peter also points out that a Valet parking attendent who only engages the dog teeth synchros in first gear (and not the gear itself) can destroy the synchros, in one move. HTH
Old 02-16-2003, 12:35 PM
logician's Avatar
Hi,
My old '85 Carrera had 137K when I bought it (915 transmission), and the synchros were gone. From what I've seen, I would agree that on average, you should expect 100K, maybe a little more from a 915. But it all depends on how the car has been used. It's usually the synchros that are in need of attention. Also, different drivers may be more or less sensitive to weak Synchros. I lived with very weak synchros in my second Porsche, my 930, for 3 years because by then I had learned to match engine revs to car speed.
-Juan
www.ArtOfRoadRacing.com, Thunderhill, 30 Jan 2011
ArtOfRoadRacing@gmail.com
SM #34, '04 GT3, '73 911s, '70 911 2.7L PRC Toyo Spec #11
Old 02-16-2003, 12:51 PM
Geary's Avatar
I've seen shift sleeves in a 901 dragrace tranny go bad after about 10 passes. Since these are virtually the same as 915 shift components, this gives you some indication of what extreme abuse (speed shifting) can do to your 915. On the other hand, treated nicely, the 915 will likely last well over 100,000 miles.
Old 02-17-2003, 03:25 PM
pwd72s's Avatar
Unless Dave, your transaxle happens to contain the factory limited slip...if that's the case, you might do well to consider upping the price just a wee bit...a grand or so...new factory limited slips are well over 1K...
Old 02-17-2003, 07:07 PM
Buy them, sell them
Adam's Avatar
My '76 915 lasted almost exactly 100k (160k kms) before it went Ka-Fluey! Synchro Hubs, Synchros, dogteeth and approx $1300 (US) later it shifts like butter and is better than ever.
My mechanic told me that they tend to last 100k miles in "weekender" type cars. Maybe they get thrashed more than the babied daily-drivers.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 02-17-2003, 07:43 PM
