-   -   1986 turbo - Troubleshooting ignition failure (http://forums.pelicanparts.com/porsche-911-technical-forum/974581-1986-turbo-troubleshooting-ignition-failure.html)
tasturbo86 10-19-2017 09:43 PM
Is there a checklist for troubleshooting ignition failure on a 1986 911 turbo?
My factory manuals only describe steps for older turbos.
My coil did not meet resistance specs, so I replaced it, but still no spark.
timmy2 10-19-2017 10:56 PM
Which CDI do you have? Permatune, Bosch?
Green wire in good condition?
Is there power to the white "T" 2 pole connector below the CDI on the red wires? (Fuse 11 or 12 up front if not)
john walker's workshop 10-20-2017 04:34 AM
The delayed ignition cut-off relay is a common failure. Check that 12V goes in and back out on the way to the CD unit. Or just check for 12V at the CD unit first, then if not, back track to the cut-off relay. A jumper wire with spade terminals can be used to by-pass the relay if needed. Remove relay and jumper at it's plug.
brasch 10-20-2017 04:59 AM
You should jump your relays to test if they are the culprit, http://forums.pelicanparts.com/uploa...1508500689.jpg
tasturbo86 10-20-2017 05:04 AM
Timmy2 - I have the original 6 pin Bosch. I'll have to look for the white "T" when I get to the barn.
I bought a crapload of those old style fuses to replace all of them!
tasturbo86 10-20-2017 05:16 AM
John Walker,
Where is that cut-off relay on Brasch's picture?
tasturbo86 10-20-2017 05:17 AM
Brasch,
Nice document!
Where can I get a full copy?
tasturbo86 10-20-2017 12:19 PM
920 no start
If I hear the CDI squealing, does thatmean it is ok, or just getting power?
john walker's workshop 10-20-2017 12:35 PM
If it squeals, it's getting power, but that doesn't mean it works. No spark, probably a bad CD. Might want to send it to Ingo here on the forum or to Loren at Systems Consulting, Manhattan Beach Ca to check it.
brasch 10-20-2017 12:35 PM
THE yellow relay should be G on this, you can bypass all of them with jumpers which is what the blue line shows to see if it works. I got these from the boards here, used them to require all my electrics and hookup all the safeties again on my 86 turbo motor. I made jumpers from wire and some tweaked bullet connector ends, I leave a couple in the car Incase a relay goes bad http://forums.pelicanparts.com/uploa...1508528067.jpg
tasturbo86 10-20-2017 03:28 PM
Looks like you still have an air pump?
tasturbo86 10-22-2017 05:09 PM
If my CDI is squealing and my coil is new, does it come down to the CDI and the distributor as the possible culprits?
pa911 10-22-2017 05:31 PM
Are you getting power to the coil? have you checked the coil wire to the distributor? checked Rotor?
brasch 10-22-2017 05:41 PM
And have you checked that you are getting power to your the fuel pumps
tasturbo86 10-22-2017 06:22 PM
coil
Is the coil constantly powered, or does it get power for each cylinder?
Coil wire to dist 'looks' great. It does not have a connector outside of the dist to test at.
I will have to trace back through the harness to see if I can get AC voltage.
I had to order a new multi-meter to read small voltages - .1V, I think is what I should see.
tasturbo86 10-22-2017 06:25 PM
Power to the Fuel pumps?
I did jumper the #2 fuel pump relay for one test, but still no spark
tasturbo86 10-31-2017 03:23 AM
I sent my CDI to Ingo.
If it tests GOOD, I'll have to go after the green wire, which is difficult on my engine.
It disappears into the harness, with no connector to put test leads on.
I'll have to pull the distributor for further testing.
If I need a new green wire, where could I source it? I certainly don't want to buy a new engine harness.
T77911S 10-31-2017 03:54 AM
you can check the green wire at the connector for the CD.
should be around 500 ohms between the 2 wires, 31d and 7
the 500 ohms is the coil in the dist.
another reason I like my MSD. it has an LED on it that shows it is getting the trigger form the dist. came in handy when my coil died on the road, popped my spare coil in and off I went.
tasturbo86 10-31-2017 04:04 AM
T77911S
Thanks! I'll try that today.
MSD may be in my future, but I'm trying to stay stock.
I already removed the air pump crap and put a Ruf muffler on it.
Some day I'll have to explain all the changes to a new owner.
terry
T77911S 10-31-2017 09:23 AM
just keep the original parts.
I went with MSD because I removed all the crap from under the seat and still wanted an electronic rev limiter that was adjustable.
borla exhaust? I have one too along with a zork. that borla really sounds nice.
tasturbo86 10-31-2017 10:33 AM
exhaust
Ruf exhaust - made by Alois Ruf. He modified the standard 2-pipe turbo muffler to add 2 more pipes on the other side. I'll take a pic when I do the test you mentioned.
RUF Automobile GmbH – Manufaktur für Hochleistungsautomobile
tasturbo86 10-31-2017 12:15 PM
testing distributor green wire
T77911S,
580 ohms. looks good. Thanks for the suggestion!
Now, I am waiting to hear if my CDI tested bad.
That would be good news, even though it costs $200+.
Just to bore everyone, here is a shot of the Ruf exhaust.
I visited his shop 31 years ago after taking delivery at the factory.
He took me for a ride in a customers turbo and I saw 300kph on the speedo.
A super guy and very solid Porsche solutions.
http://forums.pelicanparts.com/uploa...1509477178.JPG
billjam 11-02-2017 05:48 AM
Originally Posted by tasturbo86 (Post 9783731)
Brasch,
Nice document!
Just came across this thread ... links to my original files are in links setup by Tremelune at post #58 in this thread. :)
tasturbo86 11-05-2017 03:57 AM
Thanks billjam!
CDI tested bad - repaired and in the mail to me now. Fingers crossed!
tasturbo86 11-08-2017 03:08 PM
Thanks to all who replied!
The CDI box was bad.
John Walker suggested Ingo (username ischmitz) and he did a swell job.
Now, I have to repair 31 year old CV joint boots.
It never ends.
terry
T77911S 11-09-2017 03:39 AM
check the 930 side under jfairman. he found another CV boot that may be better
tasturbo86 11-09-2017 04:02 AM
I had noticed a slight whining sound while on the club tour before the CDI died.
I was hoping it wasn't a rear bearing, as I recently sold my bearing puller kit here.
Since the joint may have run dry for a while, I will go ahead and do the kit that has the joint in it.
I may pull the engine and work on some oil leaks. Also want to replace the A/C hoses.
The A/C was dead when I took delivery and it never held a charge. I don't drive it when it is hot out, but I'm trying not to let things go.
My wife understands how I feel about the car. We picked it up at the factory and we also drove it to our wedding. Kinda special.
Jonny H 11-09-2017 08:25 AM
Originally Posted by tasturbo86 (Post 9797243)
T77911S
Stock looks, better performance, fully 'mapable' for ignition timing...
911 CDI+ (6 Pin) - Classic Retrofit
