evan9eleven's Avatar
[QUOTE=Canada Kev;9788337]Here's what mine looks like...
As always Kev, you take things to a higher level. Even a frunk light switch is so elegant.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 10-24-2017, 01:42 PM
As SpyderMike said...
I got rid of the front and back lights. Also pulled the interior light bulbs, I was working on the car and left the door open. Almost killed my Odyssey. They really don't work as well as a good led flashlight.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 10-24-2017, 06:01 PM
echecsqueen's Avatar
ok today I stole Kevin's idea and mounted the switch in my Renncover
Love ir...simple and elegant solution
Since you say you are a newcomer like me, here are the exact instructions for putting in a switch
(please dont be insulted by the simplicity)
I used an on off type switch from amazon
https://www.amazon.com/gp/product/B01G821G6A/ref=oh_aui_detailpage_o06_s05?ie=UTF8&psc=1
I first inserted the switch into my red cover and locked it in
then I cut the black wire leading to the trunk light (there should be a brown and a black)
Inserted the switch into the black line - I soldered and shrink wrapped each solder
viola
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 10-27-2017, 10:32 PM
1988 Carrera
shadowjack1's Avatar
i did this just a few weeks ago. i was running down my batt with the bonnet open .
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 10-28-2017, 04:50 AM
viola
loved the "closer....viola" thought i was the only one who used that bastardization!
thanx so much for your help. steve
Steve Meltzer
'69 911E/bastard
Old 10-28-2017, 06:27 AM
bugstrider's Avatar
Trunk light question
Ooooooohhhhh, squirrel!!!(inside joke)
Must do this to our's too. Will tap into the frunk light power to run these that will be tucked up and out of sight, but will provide additional light when needed.
Cheers
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 10-28-2017, 08:02 AM
Cool! I just ordered some similar LED strips for my interior footwells for when I drop something on the floor in the dark. What were we talking about?
Oh yes - the switch. While I was cleaning up that job today I got distracted by my cover and redid the fasteners. I will post this project on my thread
Queen Customizes her 3.2
The Queen customizes her 3.2
Old 10-28-2017, 07:08 PM
Formerly known as Syzygy
Canada Kev's Avatar
Yeah, when you drop something on the floor, lets go with that...
Are they purple and dimmable...? Did you also get a Marvin Gaye or Barry White CD at the same time?
Marvin Gaye - Let's Get It On
Kevin
Old 10-28-2017, 07:48 PM
That really made me laugh/ great memories - anyway, my car is accented in red not purple
Marvin Gaye cassette for my Blau...but I do like Barry also
Old 10-28-2017, 08:09 PM
Banned but not out, yet..
RSBob's Avatar
I would love like to see a creative solution for a LED or light above the ignition switch and not the illuminated key solution.
Old 10-28-2017, 08:12 PM
Old 10-28-2017, 08:20 PM
Canada Kev's Avatar
That actually would be pretty simple. An LED could be mounted to the plastic surrounding the steering column, just ahead of the signal lever. Theres a nice flat spot on the lower half that seems to be pointing in the direction of the ignition switch. There's access to power behind the dash right there and it could be run from the door switch which is located nearby. It could be wired to come on with the door open or if you wanted to get all fancy, latch it on when the door opens and off with the ignition switch turning on.
Kevin
Old 10-28-2017, 08:28 PM
Canada Kev's Avatar
I know about your red interior bits (the woman I was seeing is an interior designer and freaked out a little when I told her what you were doing with that vintage fabric), but was just going from my memories of the '70s...
Kevin
Old 10-28-2017, 08:34 PM
Originally Posted by Canada Kev View Post
That actually would be pretty simple. An LED could be mounted to the plastic surrounding the steering column, just ahead of the signal lever. Theres a nice flat spot on the lower half that seems to be pointing in the direction of the ignition switch. There's access to power behind the dash right there and it could be run from the door switch which is located nearby. It could be wired to come on with the door open or if you wanted to get all fancy, trigger it on with the door and closed with the ignition switch turning on.
nice idea!
Old 10-28-2017, 08:40 PM
Canada Kev's Avatar
'Twas Rick's idea, I just thought of a way to make it work.
Kevin
Old 10-28-2017, 08:53 PM
RSBob's Avatar
Kevin, excellent suggestion. I have an extra LED I will wire in pointing to the switch. Your solution is far safer than drilling a hole above the ignition. I appreciate you giving me the credit, but the pure genius is crafting the solution.
Old 10-28-2017, 09:35 PM
If you told her it was '65 vintage Fortuny I bet she did freak! I can't imagine a better use for it.
Old 10-28-2017, 09:41 PM
Canada Kev's Avatar
Yep, told her it was Fortuny from the '60s. She asked if it was pillows you were using and went a little bit pale when I said you had a few yards. It was rather funny, but I like to shock people - kinda odd that way...
Kevin
Old 10-28-2017, 10:11 PM
bugstrider's Avatar
I think there should be a thread started with the title.....
"Flight of the Bumble Bee"
Could be on all the side details that get started when we all go in to fix one item only to get derailed onto a totally different item. lol.
Oh yeah, back to the LED interior lights. Actually "JoeBob" is the one who turned me into the LED strip lights for the interior footwells and the engine bay linked to an Independant switch. The idea recently resurfaced when including those for the frunk area too. Bright light n low power consumption = win win for our cars. Especially if one looks into the lighter smaller battery.
Cheers and happy Sunday
Today's frunk-space tool go-for.
1978 911SC Targa
Old 10-29-2017, 01:04 PM
disband
juanbenae's Avatar
someone said "elegance"?
Old 10-29-2017, 01:46 PM
