Porsche ran them in and matched them, but not enough for it to matter if you have brand new parts. But put 50 or 75k on the parts and now they have bedded in and matched to each other. You want it to keep running quietly, you want to take it back to that same setting. On the rebuild, if you haven't changed anything, step one is recheck it, and if the pattern was good to start with, you're good. But let's say you are adding an LSD? Then you go through the whole process according to the book. When it is done, then you print it again. If the print is way off, I am not going to leave it like that. I am going to assess what is wrong and attempt to fix it with minor changes to shimming. this is from a Corvette forum, but gives a good idea of how to read a print. http://corvettepartsonline.net/siteb...01-760x721.jpg |
Cool thread with nice pictures. Appreciated.
I am rebuilding my ZF 911SC LSD right now so appreciate the listing of part numbers. I am going to refresh it it with factory internals and put it up for sale in the classifieds in the next week. Moving to a Guard diff since my application is racing. Thanks for the thread and contributions by the community. |
No worries on the LSD. It gave me the opportunity to tear it apart and rebuild it, so now I understand how it works and have it set up in spec. I look at it as a great experience. Thanks for stopping in! Quote:
The yellow paste in Matt's Corvette illustration is General Motors Gear Marking Compound.
I've been using it, and three or four other marking solutions, since the late 70s. http://forums.pelicanparts.com/uploa...1516827295.jpg Using the tools to duplicate the manufacturer's specs is far more accurate than running patterns, and I've been doing both for four decades, at many levels including CART IndyCar. There are reasons that manufacturers create expensive tools and instruments to do this, instead of just providing a $20 tube of paste and an instruction sheet. You cannot accurately duplicate the loads and spreads involved when running patterns by hand. It will only get you reasonably close, if the tools and instruments are not available. There are also different methods of running patterns for Hypoid, Palloid or Cyclo-Palloid gears, Klingelnberg, Gleason or Oerlikon gears, etc... Like many other things, it is not as simple as whatever various random people might post on the internet. |
And on that note, I've located a nice example of the VW tool Ken posted on the previous page. I'll get it professionally machined and give it a go, adjust if needed, print the ring gear, use the washer tool, and see where the backlash is then. I'm going to get this gearbox set up no matter what!
It would require a few precise machining operations to the VW tool, and to the VW setting block. If you don't have access to the VW385 tool and can find a VW289d, this will probably work for you. P258 was the original pinion tool for the 901 transmission, and was used into the 915 series with additional sleeves and a new setting block. http://forums.pelicanparts.com/uploa...1516834771.jpg Here are the P258 and VW289d tools together, for comparison... http://forums.pelicanparts.com/uploa...1516834806.jpg The original setting blocks for the Porsche and the VW tools... http://forums.pelicanparts.com/uploa...1516834840.jpg |
Thanks Jon. Man would I love to tour your garage. It seems you have one of everything! Below is a pic the VW tool that is on its way to me, I should have it in about a week to 10 days. Machining the spigots seems straightforward: get my machine shop to center it properly in their lathe, and machine down the spigots to 50mm diameter, same as the carrier bearing ID. The machining should be such that the bearings can be set the correct distance apart which Ken said was about 120mm. Machining the block is a bit more scary. Again, I'll get a professional shop to do this for me, but it is getting the right measurements to give them I will need help with. Since you have the actual tools and blocks, can you offer any advice here? Essentially, how deep to machine into the block to have 66.30mm be the zero point, if I'm understanding this correctly. http://forums.pelicanparts.com/uploa...1516872913.jpg |
It will be a shame to chop it up :-( The measuring distance to the setting block will be stamped on the plaque as Istmaß mit Einstellmeister. It will be about 58.70mm. Since you're trying to achieve a measurement of 66.30mm, you would deepen the setting block by the difference, about 7.6mm. Instead of machining the setting block as Ken did, you can put gauge blocks on it instead, to achieve the same 7.6mm difference, or create a precision 7.6mm spacer. That's it for me tonight, Evan, gotta go... |
There is a way to DIY the pinion depth tool. You will need an open diff, or yours disassembled to do it. Go to this tread for more details.
http://forums.pelicanparts.com/porsche-911-technical-forum/337213-xperts-ring-pinion-patterning.html http://forums.pelicanparts.com/uploa...1516899433.jpg |
Porsche never recommended doing this, but some manufacturers reasoned that the special tools involved might not be available to many repair shops. http://forums.pelicanparts.com/uploa...1516910334.jpg http://forums.pelicanparts.com/uploa...1516910364.jpg |
Still following this thread.
Mr. Evan9eleven: Mahler's 9th is my favorite piece of music. But it is not for everyone. I also like many other Mahler compositions especially the 2nd and 3rd symphonies. I am rebuilding what appears to be the same diff you have. I have some questions about your LSD rebuild: What spec did you use for the stack height and margin? The 5.20 mm spec seems to apply to the later Carerra diffs, and I wonder if it also applies to the range of SC LSDs. My LSD has four plates and one friction disc per side. Is that what yours had? It seems that you used two friction discs per side in your rebuild. Is that correct? And what was the stack order you used? Did you build it for 80% or 40%? Good luck with the ring and pinion set up. I did this once on a 968 box with tools I fabbed up. Very time consuming but rewarding. If I recall correctly, the biggest pain was not having a press. After I was done I took it to a shop and they double checked my work. Even though I now have a press, I am having a shop do my next R&P set up... buying a Guard LSD this month. Thanks again for such an interesting and informative thread. |
915 Rebuild
Jon B's suggestion of using gauge blocks to change the Vw 289d setting depth sounds good.
Another way to get there would be to use a VW 385/17 magnetic plate on the pinion face. The plate is 5mm thick which would reduce the effective R from 66.30mm to 61.30mm. The difference between 61.30mm and the VW 289d setting block's 58.70mm is only 2.6mm which means the dial indicator could reach both points. A magnetic plate costs about $100 though so it would probably be cheaper to modify the block. |
Below are my measurements at dissassembly. Basically, the diff tested at a breakaway torque of 26 lb-ft, which is below spec for this unit (an '81.) The clutches and steels were well worn, expected after 165K miles. The one side was more worn then the other. I followed Paul Guard's link for disassembling and measuring everything and discussed the results with Matt. He assured me that going to a 4-clutch setup (80%) wouldn't have any downsides for a street hotrod like mine, so I ordered new parts and rebuilt it. It was actually very easy to tear down and rebuild, follow Paul's guide and its cake. Great to have a press, all your parts ready, and don't forget the locking tabs for the diff ring bolts and a bottle of LSD gear oil. It took me one evening to tear it down and clean it and another evening to rebuild it. I reused the thrust washers, 1.4mm lamina discs, and Belleville washers (cup springs.) I purchased 4 new 2mm steels and 4 new 2mm clutches and installed them alternating. This is what everyone refers to as 80%, though again, I've been advised that this will work for my needs. From the outside the order is: Thrust washer; Belleville washer; 1.4mm lamina, 2mm friction disc; 2mm steel; 2mm friction disc; 2mm steel. Same on the other side in opposite order. Breakaway torque after rebuild is 47 lb-ft, about in the middle of spec for this arrangement. My numbers after teardown (old parts): Body depth: 100.6mm -Cover depth: 8.5mm = 92.1mm Belleville washer material thickness: 2.45mm both sides Pressure ring assembly: 68.21mm Plates and discs, ring gear side: 1.35mm 1.86mm 1.95mm 1.95mm (friction disc) 1.96mm =9.07mm Plates and discs, speedo side: 2.0mm 1.97mm (friction disc) 1.99mm 2.0mm 1.39mm =9.35mm So, the whole stack including the belleville washers was: 91.53mm vs. a body depth under the lid of 92.1mm. Hope this helps! http://forums.pelicanparts.com/uploa...1517003709.jpg |
Thanks for those details. My existing stack is a bit diffferent-- I don't think it is what was shipped by PAG.
If anyone has interest I will post what I found in my unit. I called a few dismantlers-- it appears these LSDS are hen's teeth. Hopefully that will help when I go to sell mine. The world is small... yesterday I met the gentleman how owns/owned the diff from Paul Guard's rebuild thread. Very nice gentleman. Small world indeed. Rite of Spring and Firebird are two other pieces I like-- main stream Stravinksy pieces. Stravinsky and Mahler were connected-- at minimum through Alma Mahler. She was one of those "center of the star" folks. Even connected to modernest architecture. |
By the way, I think you are all set on teh ITB/EFI part of your project but just in case...
I think the new cat's pajamas in ITB's are the shaftless butterfly rigs. The US co-developer for Porsche applications is my engine builder. I cannot use them (not legal for my racing class) but if I were interested in ITBs and power with EFI, I'd consider that new family of ITB products. We have quite a few guys already running them and they make quite a bit more power than everything that has been previously available. |
I guess its time for a teaser on the upcoming ITB portion of this thread, the X-Faktory santa was very good to me. Just as soon as the gearbox is done I'll start on the engine. http://forums.pelicanparts.com/uploa...1517173922.jpg http://forums.pelicanparts.com/uploa...1517173922.jpg |
What are your plans for filtering intake air?
| All times are GMT -8. The time now is 04:27 AM. |
