Sven
Aussiesven's Avatar
What are those connectors on 3.2L engine?
I am sure this is a very simple question...
There are three connectors at the back left of the engine. The top white one is broken, so I need a new one, but cannot work out what it does or what the part number is...
I have zippy tied it together for now but need a new plug.
Anyone know what those three connectors hook up to or even the part number? Thanks in advance.
Sven
Sven
1985 Porsche Carrera LHD black on black
1970 Citroen DSuper RHD Bleu Platine with Blanc Cygne roof
1968 Porsche 911 LHD red on black (sold - shouldn’t have...)
Old 12-19-2017, 01:04 AM
proporsche's Avatar
hi there....
the search button on top right should give you plenty of answers...for now here is some
Ivan
and here
Head Temperature Sensor Replacement
and some reading
https://rennlist.com/forums/911-forum/615361-reference-sensor-gap.html
Old 12-19-2017, 01:54 AM
The strapped connector is head temp sensor.
Bruce
Old 12-19-2017, 02:03 AM
Sven
Aussiesven's Avatar
Excellent gentlemen. Thanks for the quick replies. Another job on the to do list... would Bosch sell only the connector? My wiring is fine, just the connector male part is broken...
Sven
Sven
Old 12-19-2017, 05:09 AM
The male side (the yellowish part) is part of the head temp sensor, not replaceable separately.
206 637 4071
Old 12-19-2017, 06:37 AM
/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
Is the female side connection available somewhere? Mine is broken too, but on the wiring harness female side and rigged similar to the OP's picture.
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 12-19-2017, 07:05 AM
steely's Avatar
Here is one Parts source. They're called Junior Timer Connectors (ancient name).
AMP Connectors/Terminals
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-19-2017, 07:27 AM
Cevan's Avatar
Please tell me there is a tool out there that makes it easy to remove the little spring clip on these connectors. Can't believe Bosch designed and used these things.
1986 Carrera coupe - black on black
1972 CB500/4
Old 12-19-2017, 07:41 AM
Undocumented User
McLaren-TAG's Avatar
I know it sounds dirty but just give it a firm tug.
Old 12-19-2017, 08:04 AM
steely's Avatar
+1 on the tug.
if you use a small screw-driver to lift the sides instead, just be careful as it could go airborne
Dan
Venetian Blue
Old 12-19-2017, 09:38 AM
Yep just stick a small screwdriver in between the end of the plug and what it plugs into and gently pry (twist) it and it will pop right off. I did all kinds of gouge damage to the plastic trying to remove (and reseat) the stupid spring clip before I learned this.
Old 12-19-2017, 09:58 PM
Elombard's Avatar
Yeah they are designed to pull off, right? I spent so much time removing the spring clips thinking there was a special tool and I realized several years later "I think these just pull off".....of course I just broke the heat temp plug doing that. That sucker over heats me thinks
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 12-20-2017, 05:06 AM
Cevan's Avatar
Learn something new everyday. Thanks.
1972 CB500/4
Old 12-20-2017, 07:44 AM
RLJett's Avatar
I removed each spring clip with a pick ... pulling on one end of the spring and pulling away from the connector body. Then I used my fingers to grab the spring and the unhook from the other side of the connector. I was warned the springs may go flying, so I laid down a plastic sheet unit the connector area to prevent them from falling in the engine area.
Rob
1985 911 Carrera Targa
2016 Boxster Black Edition
Old 12-20-2017, 08:44 AM
faverymi's Avatar
I use a dental curette
I should start selling the old dull ones here
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 12-20-2017, 08:50 AM
Ausie. you have a PM.
Old 12-20-2017, 10:10 AM
