"Der Hellion"
roctor's Avatar
Send a message via AIM to roctor
Question Engine get hot a stalls after 20 miles.
Car starts and runs fine. Then after 20 miles the interior of the car feel like its on full heater blast. Engine cuts off and will not start until 30 minutes of cool down. All interior air ducts are off. Is this heat from the engine causing a vapor lock? The ca r is a 1974 2.7. Thanks Roger
Old 10-12-2017, 04:02 PM
What is the temp gauge reading when this happens? John
Old 10-12-2017, 04:06 PM
Flojo's Avatar
Originally Posted by roctor View Post
Car starts and runs fine. Then after 20 miles the ... Engine cuts off and will not start until 30 minutes of cool down.
sounds like a bugged CDI-unit... either the coil or the box.
I had the same phenomena and it was my box.
do a search here for CDI, lots a posts that help tracking down issue.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-13-2017, 04:36 AM
T77911S's Avatar
cd or coil.
coil is cheaper and if that is not it you have a spare to carry.
sounds like the heat is on
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-13-2017, 05:35 AM
"Der Hellion"
roctor's Avatar
Hello Folks, In the middle of moving. I have not forget you. The car has MSD ing. and coil. Hope this helps. Roger
Old 10-16-2017, 09:01 AM
"Der Hellion"
roctor's Avatar
Coil it is. Thanks Roger
Old 11-05-2017, 02:19 PM
"Der Hellion"
roctor's Avatar
jjefferies Asked what my oil tenp. was. Well the temp. was pegged while the oil pressure remained normal. ???
Old 11-05-2017, 04:28 PM
"Der Hellion"
roctor's Avatar
Engine was two courts low.
Old 11-07-2017, 02:12 PM
