Ssi heat exchangers question
Hi,
The more I learn about the ssi heat exchangers the more questions I have.
My car is 1976 2.7l two heat exchangers into one out to the muffler.
My questions are:
Is there ssi heat exchangers two in one ?
Are the original oem setup two in one still sold by anyone?
If not then I need new muffler , true?
What other hardware do I need if I go with ssi and new muffler? Oil lines?
I have recently learned about bisimoto pulse chamber which from what I can see is only meant for the two in one setup.
Thank you
Photo of my oem setup
Old 11-04-2017, 03:38 PM
Somewhat obsessed......
SSIs
Hello! The SSIs need a “2 in” muffler. There are many flavors of mufflers and you can drown (immerse?J yourself in reading about them. But there is no cross over exhaust pipe with the SSI so you need a two inlet muffler. Also you need to change the oil line.
I can’t remember but I think two of them. One line goes where the previous cross over pipe lived.
Also there are two flavors of ssi. Thick flange and thin flange. I think you need thin but you better double check !
Hope this helps..
BTW I put SSI on my SC with a M&K 2 in 1 out and love it!
Chris
'83 Super Carrera
......There are many like it, but this one is mine.
Old 11-04-2017, 03:52 PM
Reiver
Reiver's Avatar
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-04-2017, 03:54 PM
That setup is beautiful.
At the moment I want to fix the oil leaks and get away with what I have until I really know what I want.
Factory he will do fine for now. I need to find a set.
Old 11-04-2017, 04:53 PM
Flojo's Avatar
Same here. Best mod ever!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-05-2017, 02:51 AM
Bill Verburg's Avatar
Originally Posted by kavadarci View Post
Hi,
My questions are:
Thank you
I sense some confusion here
First SSI is a trade name for heat exchangers that replicate the header design used on most 911s thru '1974. This design uses a muffler w/ twin inlets.
stainless steel(ss) is a material that is used to construct better exhaust systems. SSI uses ss in it's construction but so does the newer versions of factory heat exchangers.
By around '76 factory heat exchangers & mufflers were made of ss. The ones you pictured appear to be ss.
ss can corrode w/ time. If you need new, then the factory versions are available from Porsche or you can update to the more efficient older design w/ twin pipes going to the twin in muffler made of ss by SSI
Bill Verburg
Old 11-05-2017, 05:29 AM
Good explanation, that picture above is not from my setup. Here are mine. The heating hoses were removed and I can see he heater flapper boxes are completely gone.
Come to think of it, how would one know that the heat exchangers are gone?
I only know what the original owner told me.
Old 11-05-2017, 05:40 AM
Look for holes on the metal, Porsche designs these parts in a clever way. The outer(visible) metal is designed to corrode faster than the inner(critical) metal. Holes will appear in the shell long before the inner is perforated. Perforation of the inner is the critical part because that's what allows CO to enter the cabin.
From the last pic the heat exchangers appear nominal, Your heat issue is likely to be w/ the chassis valves which are a definite issue and lack of hoses.
Bill Verburg
Old 11-05-2017, 06:47 AM
I agree with you.
I do plan to take them out this winter to fix the return tube and oil cooler leaks so I will inspect them properly for any holes.
I also plan to get he heater flapper boxes first and I do have the heating hoses.
Thank you.
Old 11-05-2017, 08:47 AM
Under the radar
Trackrash's Avatar
Kava..., I guess you don't have to worry about smog tests for your car, as you don't mention your location. "SSI"s are the way to go, if you don't have to worry about originality for emissions.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-05-2017, 12:55 PM
Originally Posted by Reiver View Post
*****in! My setup will look similar!
Old 11-05-2017, 07:25 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
I swap my SSIs every 2 years, keeps the nuts and studs free and I get the added benefit of under car inspection in detail. Worth every second for the SSI music that comes out of the M&K!
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-06-2017, 07:58 AM
theiceman's Avatar
here is pretty well everything you need.
Plus 6 new head to ssi gaskets and two for the muffler.
Then you need to bend a couple of wrenches but I have not done that yet.
also make sure you get the correct SSIs as there are thick and thin flange. Same if you just replace your current exchangers. Make sure you get the right ones. I believe yours are thin flange.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-06-2017, 08:13 AM
I love the way my SSI and Dansk Sport 2 in 1 out sounds. Not to loud. It is definitely louder then my stock muffler.
Old 11-06-2017, 09:46 AM
WP0ZZZ's Avatar
Are there louder options for 2 in 1 mufflers that look stock from the outside?
Old 11-06-2017, 10:06 AM
If you want the look of a stock muffler either Dansk Sport or cut open your stock muffler and modify. MK muffler 2 in 1 out is louder, but doesn't look like the stock muffler.
Old 11-06-2017, 10:17 AM
sp_cs's Avatar
Not cheap:
http://www.dw-technik.de/produkte1/01_dw11270.php
Old 11-07-2017, 03:39 AM
Flojo's Avatar
not sure what you really hope for, but I must say I didn't want my Dansk 952 mussfler 2:1 to be any louder. Would it be louder it might be fun for 10 minutes, but on a road trip or so, you'll hate yourself.
Old 11-07-2017, 03:45 AM
WP0ZZZ's Avatar
If I recall correctly, there are no Dansk Sport mufflers in 2-in-1 configuration. Buying a normal one and cutting it open is definitely an option but will require some trial and error that I would prefer to avoid.
Originally Posted by sp_cs View Post
Ouch! Never heard about this brand before. Are they good?
Old 11-07-2017, 03:51 AM
sp_cs's Avatar
I like mine - great quality, and frees up a few hp over the dansk 2-1 it replaced
Note, you can buy a dansk sport 2-1, even an SSI badged item
Shirish
1987 Carrera, Granite Green
Old 11-07-2017, 03:58 AM
