bcgreen's Avatar
Brake light question
'76 Carrera.
Tail lights work, license plate lights work, turn signals work, drivers side brake light works, but the passenger side brake light does not work. Where to start?
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-17-2017, 08:28 AM
New-ish 911SC Targa Owner
pampadori's Avatar
i have found that the prongs that contact the bulbs sometimes need to be pulled/bent to make better contact. i use a little curved pick tool to grab the prong and pull it out a little more. make sure the key and lights are off unless you like blowing fuses.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 11-17-2017, 09:05 AM
bcgreen's Avatar
Will do and report back on my progress.
What's the best way to access - behind the bumper or take off the tail light assembly?
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-17-2017, 09:10 AM
ROW '78 911 Targa
timmy2's Avatar
No need to remove the housing.
Take off the lens cover, pull the bulb and use some skinny needle nose to pull/bend them out a bit.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-17-2017, 02:30 PM
bcgreen's Avatar
Took bulbs out from each side. Cleaned contacts on bulbs and pulled the prongs and scratched them a bit.
When I hit the brake pedal, only the passenger brake light comes on.
Now if I turn the driving lights on, I see all driving lights are on. When I press on the brake pedal the driving light on the driver's side goes out and the passenger brake light comes on.
Update: Clean the driver's side brake light some more (aggressively) and now it works. So it came down to basically cleaning contacts.
Next up is the back up lights. I suspect it is going to be the switch, but presently I am trying to get the car up high enough that I can get under there to take the support bar off. Looks like I may have to look for someone who has a floor jack that goes up high enough.
Thanks for the help.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 11-17-2017, 04:28 PM
RDM RDM is online now
Coram Deo
RDM's Avatar
With the lenses off, it's easy to check if you have voltage to the back up lights when the car is in reverse. If not, then trace the wires back until you find where your connection is lost (which, as you noted, involves laying under the car).
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 11-18-2017, 11:22 AM
