proporsche's Avatar
Show the most genuine modification to any 911 parts
As suggested here it is .
Show if you are not afraid, the most genuine modification to any Porsche 911 part you have experienced or seen....
Ivan
I have so far this clock...but not bad at all..or?
Old 11-06-2017, 05:59 AM
bourgeois911's Avatar
I did pretty much this exact thing 10 years ago or so. Inserted a 10 buck quartz movement and change the AA battery annually. It keeps better time since it doesn't use the car battery which gets disconnected from time to time.
Tom
79 911 SC
Old 11-06-2017, 07:26 AM
evan9eleven's Avatar
Show if you are not afraid, the most genuine or idiotic modification to any Porsche 911 part you have experienced or seen....
Ivan
That is brilliant! A good, simple fix.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 11-06-2017, 01:36 PM
Undocumented User
McLaren-TAG's Avatar
I was putting the quarter windows back in my car after getting the car painted. there's a metallic piece the goes on the body, looks like this.
Well I come to find that it required a strip of caulk down beneath it and the body. Can't find the Porsche part number for it but I sure as hell wasn't going to wait for it so I took out m plumber's putty that's what was basically there anyway, except in a neat little strip. I strung a long bead along the entire length and then bolted the metal strip down. Perfect and instant and, well seeing this clock reminds me of the many ways to skin a cat if you're not a purist mentality.
Old 11-06-2017, 03:27 PM
Registered Minimalist
75 911s's Avatar
Bracket I made out of an aluminum strip to replace a huge EGR valve and bracket that I deleted.
The replacement non egr filter car bracket was something stupid like $95! H3ll naw. It's tucked back behind #3 and you can't even see it anyway.
I did the same on my front horn relocating. They are up and never to be seen again and the Carrera brackets were like $300.00
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-06-2017, 04:09 PM
Rubber Delete
I just hate those rubber air box straps, so.......
77 911s
16 981gts
Old 11-06-2017, 04:41 PM
Formerly known as Syzygy
Canada Kev's Avatar
Cool airbox straps - very industrial machine age looking.
Kevin
Old 11-06-2017, 05:53 PM
proporsche's Avatar
nice works gents-- i took of the the idiotic it was not really right;-)
Ivan
Once i have had in my hands a 1969-911 which just came to California after a long journey in Russia.
It was so rusty underneaths, someone mounted to the bottom two rail road rails just to keep it strait.Too bad i do not have any pics.. The car was raised to it`s max for clearance;-)
Ivan
Old 11-06-2017, 10:51 PM
