Help in installing an ΄73 Aluminum dash trim
Dear Friends
I need help to install this Aluminum dash trim from a ΄73 model in a ΄78 model Bassicaly I bought this parts from pelican Pelican Parts - European Automotive Parts and Accessories - Porsche BMW Mercedes Volkswagen Audi Saab Volvo MINI And I wonder If I have to remove the existing foam pad that is in the car right now? This dash trim set is only for the bottom part of it, so I wonder how the top portion (for instance the center one where the fog switch the defrost and the cigarette lighter ) will be? SInce the foam pad add a lot of thickness for the assembly of those switches and now when I remove the foam pad they will be on the car΄s sheet metal Same thing for the ignition key side, where (the ignition key, the hazard switch and the head light switch ) they all rely on the thickness of the foam pad for finishing Thanks for the helphttp://forums.pelicanparts.com/uploa...1510187771.JPG http://forums.pelicanparts.com/uploa...1510187771.JPG http://forums.pelicanparts.com/uploa...1510187771.JPG |
Foam comes off. You will need to backdate the switches as well in order to get proper fitment. Ive done this 3 times now.
You will also need backdated air controls. Your air control box will no longer fit
You will also need older style glove box door
| All times are GMT -8. The time now is 06:45 PM. |
