Question Help in installing an ΄73 Aluminum dash trim
Dear Friends
I need help to install this Aluminum dash trim from a ΄73 model in a ΄78 model
Bassicaly I bought this parts from pelican
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
And I wonder If I have to remove the existing foam pad that is in the car right now?
This dash trim set is only for the bottom part of it, so I wonder how the top portion (for instance the center one where the fog switch the defrost and the cigarette lighter ) will be? SInce the foam pad add a lot of thickness for the assembly of those switches and now when I remove the foam pad they will be on the car΄s sheet metal
Same thing for the ignition key side, where (the ignition key, the hazard switch and the head light switch ) they all rely on the thickness of the foam pad for finishing
Thanks for the help
Old 11-08-2017, 04:37 PM
Foam comes off. You will need to backdate the switches as well in order to get proper fitment. I’ve done this 3 times now.
Old 11-09-2017, 06:37 AM
You will also need backdated air controls. Your air control box will no longer fit
Old 11-09-2017, 06:38 AM
You will also need older style glove box door
Old 11-09-2017, 08:05 AM
