Removing sound deadening
When looking for possible solutions for getting rid of old sound deadening in my Porsche 911 from 1979 I have found several solutions heating up and dry ice. The best solution probably depends on the age of the car. Can anybody tell me which solution is the best for a 1979 Porsche.
Kindly regards
Steen Larsen
Old 11-19-2017, 12:53 PM
Brew Master
cabmandone's Avatar
Looks like it's cracked and chipping so I'd use a putty knife and get up as much as you can then go to heat if necessary.
Old 11-19-2017, 01:37 PM
On my 82 it was cracked and chipping like your photo. I used a petty knife and it pryed out in big chunks. There will be some residue to clean up for which I used a little citrus strip.
1982 911 Targa, 3.0L ROW with Webers
Old 11-19-2017, 02:55 PM
dlagerstrom's Avatar
Yup. Same on my 82. Much came up with just a putty knife. Used a heat gun for some areas and that helped it come up in big chunks.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 11-19-2017, 04:14 PM
Get the cheap heat gun at Harbor Freight and it should come off like butter with a putty knife.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 11-19-2017, 04:40 PM
seafeye's Avatar
Heat gun. Putty scraper and wire brush. Depending on how much you want to remove.
What me speed?
Old 11-19-2017, 05:05 PM
New sound deadening material
Thank you all for very informative answers, it's appreciated. I also need information about what you did to renew the old sound deadening material. All information about brand name or even item numbers will be very much aprreciated. Again thank you for your help.
Kindly regards
Steen Larsen
Old 11-19-2017, 06:26 PM
I didn't replace it with much. A lot of opinions here on products like dynomat so many threads to review.
Old 11-19-2017, 06:30 PM
But I would like it to look original, and Dynamat is probably not the original material?
Kindly regards
Steen Larsen
Old 11-19-2017, 06:51 PM
Dry ice. Period. Takes 15 seconds to remove all deadening
Old 11-19-2017, 07:17 PM
Old 11-19-2017, 07:19 PM
Speed Metal Army General
This!
Its soooo easy and fast this way it feels like you're cheating
Old 11-19-2017, 07:33 PM
Eng-o-neer
Tremelune's Avatar
Interior sound deadening, noise reduction, and thermal insulation
Old 11-22-2017, 04:56 PM
Thank you Tremelune for the very informative article, my problem is that I am more interested in the origianl look, and not the very best sound deadening effect. So, if anybody could send information about the original material Porsche used for 911 in 1979, I would appreciate it very much. But again, thank you for replaying.
Kindly regards
Steen Larsen
Old 11-25-2017, 12:40 AM
