no top motor numbers
motor has no numbers all have been grinded off.can someone post pick of any date codes or serial numbers picture locations, that would be underneath .all i know its a 2.7 motor thank you
Old 11-18-2017, 10:08 PM
No it’s very tough without the top numbers. There is a part number on the two case halves very easily seen from underneath that can help narrow it down some. I also think there may be a casting year underneath somewhere. I don’t think you will be able to determine whether it’s US spec, Japan or ROW without taking it all apart and a total expert looking at it. To clarify both the serial number and the case type number are missing?
Old 11-18-2017, 10:39 PM
proporsche's Avatar
Hi John..if it would be 2,7 it would have to have green engine cover not red..more likely 911sc motor
What year is the 911?The sticker(yellow) on top of the alternator housing is saying what?
Ivan
Old 11-18-2017, 11:38 PM
Identifying an unknown motor........
John,
Without the engine number on the crankcase, I would investigate the external engine parts for forensic identification. If you could provide the part numbers for these:
a). Any trace of the engine type number located at right topside of the crankcase?
b). Alternator fan housing number?
c). Intake runners (2R or 4R)?
d). Information on the sticker (alternator strap)?
e). Rotational direction of the of the ignition distributor.
f). CIS components:
WUR
FD
AAR
Throttle body
Air flow meter
CDI
Ignition distributor
Etc.
The air filter cover is from pre-SC engines. Identify if the crankcase is made of Mg or Al. Putting all these informations together would help you come to a better conclusion. Keep us posted. Thanks.
Tony
Old 11-19-2017, 05:47 AM
yellow is says 1972
Old 11-19-2017, 09:09 AM
car is a 1973,5 that sticker says 1972
Old 11-19-2017, 09:10 AM
its a 2.7 engine I've been told
Old 11-19-2017, 09:14 AM
The casting numbers on the case halves by the oil return tubes?
The double bolt fan housing retainer, early production
Bruce
Old 11-19-2017, 09:33 AM
/Users/johnjohn/Desktop/IMG_7533.jpg/Users/johnjohn/Desktop/IMG_7532.jpg/Users/johnjohn/Desktop/IMG_7535.jpg
Old 11-19-2017, 09:45 AM
proporsche's Avatar
john , your engine numbers should be here-green and red arrows, or is yours like this one?
Old 11-19-2017, 09:49 AM
mine looks like that
Old 11-19-2017, 09:54 AM
Old 11-19-2017, 10:00 AM
gearhead
73.5 will be a 2.4 on a 7R case. It the spirits were made larger on a rebuild one could install 2.7 p&c
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 11-19-2017, 10:04 AM
Old 11-19-2017, 10:32 AM
Old 11-19-2017, 10:35 AM
proporsche's Avatar
Hi John looks like you got your self pretty nice car with a nice engine..you did not mentioned if it is running?Could be 1973 911S...do you have papers for the car ?there is no info there?
here is a list to go by...
901.101.101.01 901.101.102.01 AL 1 5071
901.101.101.10 901.101.102.10 sandcast MG for 906 engines
901.101.101.02 901.101.102.01 AL 5224 9272
901.101.101.0R 901.101.102.0R AL 9730 12050
901.101.101.1R 901.101.102.1R MG 12134 15415
901.101.101.2R 901.101.102.1R MG 17421 1970
901.101.101.3R 901.101.102.2R MG 1970
901.101.101.3R 901.101.102.3R MG 1971
901.101.101.4R 901.101.102.3R MG 1972
901.101.101.5R 901.101.102.4R MG 1973
901.101.101.5R 901.101.102.7R MG 1973
901.101.101.7R 901.101.102.7R MG 1973 1977
901.101.101.7R 901.101.102.7R AL 1973 RSR
911.101.103.0R 911.101.104.0R AL 1973
930.101.103.4R 930.101.104.4R AL 1978 1980
930.101.103.6R 930.101.104.5R AL 1983
Old 11-19-2017, 11:01 AM
peon77's Avatar
Near the 901.101.101.7r case number "should" be a casting date mark. see if you can get a pic and post that. Then we might be able to say if it was originally a 2.4 or a 2.7. It might be an unstamped replacement block 2.7.
75 911s
86 951 sold to make room for baby seat
09 335i 6MT
NVH
Old 11-19-2017, 11:30 AM
its a t targa from factory its not matching motor.just trying to figure out what motor
Old 11-19-2017, 11:49 AM
no didn't get it running yet
Old 11-19-2017, 11:54 AM
/Users/johnjohn/Desktop/IMG_1630.JPG
Old 11-19-2017, 12:30 PM
